I'd tackle it the other way, looking at speakers' recommended enclosure sizes and going from there. BassBox6 Pro and WinISD could be useful...
Why not just build new enclosures that are perfectly suited to your new drivers? I'm sure you can find some help here...after all, this *is* DIYaudio!
Additional information;
The mid/bass has the following written on the back
MTX 2CX25 TDSN
M = chassis magnesium
TX = membrane “TPX”
2CX25 = size i think?
TD = something to do with the magnet?
SN = suspension “NORSOREX”, a kind of Neoprene,
8OHM
2CN12 = winds mobile 2 layers coppers (2C), on Nomex support, 12 mm length.
1377 - manufacturing number
The tweeter is a "MD900" by MA ( Monitor Audio )
Photographs of the crossover network in progress.
I'm under the impression replacing ageing electrolytic capacitors may improve things? They were 19 years old as of yesterday
MTX 2CX25 TDSN
TX = membrane “TPX”
8OHM
tweeter crossover?
http://i14.tinypic.com/2nvqhdj.jpg
other crossover:
http://i13.tinypic.com/47bro14.jpg
mid/bass back
http://i13.tinypic.com/2q07g51.jpg
mid/bass front
http://i18.tinypic.com/4h1fzft.jpg
Maybe that ferrite coil could be improved?
ICW any good?
other crossover:
mid/bass back
mid/bass front
ICW any good?
Monitor Audio is good stuff.
I'd replace the surrounds (if they're brittle), and all the capacitors inside. Double-check for voice coil rubbing, and maybe replace the internal damping - fiberglass insulation should work well.
If all else fails, just sell 'em and buy a pre-made pair of cabinets from Parts Express.
Code said:Thanks for the advice
Regarding the voice coil rubbing, im not sure how to check on this?
I have noticed there to be a small amount of 'gritty' resistance as i move the suspension up and down, could this be the voice coil?
Finally, are there capacitors you would recommend?
For caps, go with good old fashioned polyester. Apexjr has some at low prices.
Gritty resistance sounds like voice coil rubbing to me!
Hmm, on closer inspection it appears the cone is rubbing on the dust cap/rod. Is this a major issue, as it seems to sound just fine?
Regarding the capacitors, i assume 6UK160VDC means; 6uf 10% tolerance 160 volts DC.
I'm planning to replace these with Blackgates or Obligattos unless somebody advises differently.
Random.. suddenly i have harsh treble after altering my room layout .. arh!
- Improving a set of speakers
