Which is the most important TS parameter?
Thread Tools
Old 18th July 2006, 04:12 AM   #1
Wombat2 is offline Wombat2  Australia
Wombat2's Avatar
Default Which is the most important TS parameter?
I repaired a pair of 20+ year old Pioneer 12" drivers (I was told they were used in their mid to high end equipment in their day so figured it was worth the trouble and challenge) All they needed was new surrounds and one needed it's magnet reglueing (with epoxy). After repairs they measured almost identical in Speaker Workshop and sounded fine when music was played through them.
I then rebuilt the enclosures and remodelled them using several computer modelling programs. - they sound fantastic!!
This was 12 months ago and I've just got around to hooking them into the system and the one with the reglued magnet has its voice coil rubbing and therefore distorts loud low frequency signals. I think it may have sagged with standing.
I've yet to pull it apart and check it but if it is beyond help and I decided to replace the 12" drivers which TS parameters are more important in trying to match the drivers to the enclosures without too much alteration (probably limited to retuning the ports)
David L
Old 18th July 2006, 04:47 AM   #2
leonrocks is offline leonrocks  Australia
Default TS Params
Look for a driver with similar Vas, Qts, Re and Fs.
The further any of these are from the original, the more you will have to adjust the box or crossover.
Remember you can always take volume away from the box too by adding solid material. It may also be possible to increase the volume by adding stuffing material but this can have other unwanted effects.
Old 18th July 2006, 06:11 AM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Further to what leonrocks has said, you can always check out Fs/Qts and Vas x Fsē.
If the new driver comes close to original using these, then you're not too far off the money. If they are part of a multi-way speaker then you also have to consider the impedance plot for the crossover.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 18th July 2006, 06:18 AM   #4
Wombat2's Avatar
Thanks for that - they are part of an active crossover system so don't have to worry about the impedance plot - just tweek the crossover to suit.
David L
Old 18th July 2006, 07:16 PM   #5
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Vas Fs and Qts are like three corners of a triangle. Change the angles and you'll still have a triangle, but it'll look different.
Each is important in its own way.
If you want the final to sound like the original, match all three.
Old 18th July 2006, 07:42 PM   #6
R.I.P.
The Fs, Qts and Vas can be very different and still give very
near the same result when the driver is put into a box, as
it is usually the box volume that dominates.
that is : Vas can be very large, consequently Fs is very low
and Qts is very low can give the same result as Vas Medium,
Fs medium and Qts medium.
What we are really talking about is cone mass and effective
piston area and the magnet system driving it. If this is the
same for two drivers results in a box are pretty much set.
(Unless Vas is stupidly low, Fs and Qts stupidly high)
For a bass reflex ideally you want driver Vas to be ~ 2 x box volume.
If the above, you want Qts to be around 0.35 to 0.38.
(For Vas >> box volume, Qts needs to be lower)
Given the above the lower the Fs of the driver, the lower the
efficiency of the driver will be but you'll get more extended bass.
I like port tuning at Fs or fairly near above it. (Fs near 30Hz)
If you want to get near the current alignment model the Qtc of
a sealed box with the Pioneer driver and your box volume. Any
driver that models the same Qtc is that box volume will reflex
with the same alignment as the Pioneer.
As said before the actual port tuning will depend on efficiency.
/sreten.
Old 18th July 2006, 08:01 PM   #7
Svante is offline Svante  Sweden
Svante's Avatar
I recently posted the picture below on another forum, it shows the effects of altering Cms +/- 30% in a standard butterworth alignment bass-reflex box. Doing so gives fairly large effects on fs, Vas and Qts, but very little effect on the response. Changing just one of fs, Vas or Qts would give a larger effect on the response.
I guess that this supports what streten among others have said in this thread.
------------black blue red
fs [Hz]----: 35 - 40 - 31
Vas [liter]: 33 - 25 - 42
Qts -------: 0.38 0.43 0.34
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 19th July 2006, 12:27 AM   #8
Wombat2's Avatar
Thanks for the info everyone - fortunately I was able to fix the problem. When I pulled it out I could feel the piston binding when gently pressed with the driver vertical but when horizontal it was all but gone so I figure it was a very fine contact. Close examination revealed the piston stighlty off centre with the closer distance near the folded seam in the metal sleave. I wedged a business card in the gap and gave it some sideways force which appears to moved it enough. I remounted the driver with the seam down (was up before) so if there is any sagg under gravity it will open the gap more. Hooked it up and played a couple of heavy Bach organ pieces and the result is perfect - not a hit of distortion.
David L
  Reply to this post
Which is the most important TS parameter?Hide this!Advertise here!
Thread Tools
parameter conversion memphissound Multi-Way 1 28th July 2008 08:49 PM
Multimeter for T/S parameter Buzzy Multi-Way 21 9th May 2008 05:13 AM
speaker's BL parameter MisterTwister Multi-Way 24 29th January 2008 03:58 AM
where is short wiring in an amp important/ not important ? sandro600 Solid State 5 4th April 2004 04:10 AM
Req. What does this parameter mean? stigla Tubes / Valves 9 7th March 2003 08:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
