ARTA in the demo version does not allow the import of PIR files, but it is possible to save them. As someone wants to continue to use ARTA for measurements for VituixCAD, using the Spatial impulse response group record module ARTA will save PIR files even in the demo version. Thus, everything we need for simulation in VituixCAD is available in ARTA's demo package.
Joined 2003
Possibly Ivo will take the same approach as when Basta and Sirp were retired and provide a public license key so anyone that wants to use the software can use it fully. Time will tell. But mV8 is right, if you simply follow the VituixCAD measurement guide for ARTA, you will have success even without a licensed installation.
How does that work in a step by step manner?using the Spatial impulse response group record module ARTA will save PIR files even in the demo version.
You simply follow the VituixCAD tutorial, and ARTA in the demo version will save PIR files. If you want to save only one measurement, e.g. only for angle 0, you stop measuring the sequence after the program saves the first measurement for angle 0.How does that work in a step by step manner?
https://kimmosaunisto.net/Software/VituixCAD/VituixCAD_Measurement_ARTA.pdf
