Need help as I'm not sure on bipole boxes. I have a BR Box for a FR driver, the combination works pretty well. I'm thinking of trying out a bipole as I have extra FR drivers. Can I just use the same box for the bipole would I be better off making another box with double the internal volume. Feedback much appreciated.
BTW said:would I be better off making another box with double the internal volume.
You would. 2x the drivers = 2 x the Vas = 2 x the required box size... if you are doing a BRyou will also need to mod the port.
dave
