Tannoy 8" dual concentric
Thread Tools
Old 22nd July 2021, 04:08 PM   #11
krivium is online now krivium  France
Edit from previous post: ic 3d/2b
Old 22nd July 2021, 05:31 PM   #12
octavedoc is offline octavedoc  United States
Thank you everyone for your replies. Goodness, this is a great forum!
Planet10: Yes these are the ones. I assumed at low volume the size of the box wouldn't make a difference. I may be wrong.
GM: You make a good point about the "voice" tuning. I just lack knowledge about tweaking components (but am learning!)
Martyh: Based on your experience, it looks like you've had good luck with smaller boxes using the original XO.
The Dimension and Profile series use an 8" dc driver in a floor cabinet (albeit with an additional passive cone), so I thought my drivers would work well also.
I found a cap & resistor that I could add to the XO to mimic the System 800, and will update y'all. (5 uF in series with 3.3, 2 ohm in series with 2.7.)
Old 22nd July 2021, 06:37 PM   #13
fabricadetabaco is online now fabricadetabaco
I still believe 2064 is the later 4 bolt version used in S8 and D500 (sorry, not D700). The system 800 is an older driver 2046 from the Profile series. They may not sound the same and require different crossovers. Not sure about the HF driver in any of them.
2064 (????)
2046 (7300-0506)
Old 22nd July 2021, 06:42 PM   #14
And yes the crossover is probably very different in Profile 638 and System 800 due to the 2,5 way design in 638 with less baffle step correction needed. I believe the Profile series are 4 ohm while I’m sure 800 is 8 ohm same as S8LCR (bookshelf version of S8/D500). Maybe the S8LCR crossover would fit.
  Reply to this post
Tannoy 8" dual concentricHide this!Advertise here!
Thread Tools
Tannoy SandringhamClone -- 8" Dual Concentric MLTL gripracer Multi-Way 15 10th June 2020 03:38 PM
Soffit mounted 15" Tannoy Dual concentric project Actualsizeaudio Room Acoustics & Mods 78 13th November 2016 02:20 PM
Tannoy Dual Concentric 12" - Small Cabinet tralalalala Multi-Way 21 12th June 2016 11:48 AM
Pair Tannoy 2046 8" Dual Concentric with Tweeters System 800 tomlang Swap Meet 2 26th January 2014 03:04 AM
Tannoy 15" Dual Concentric - FS in NZ poynton Swap Meet 6 3rd June 2007 12:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
