DSP for active speaker crossovers using computer and sound card
Thread Tools
Old 1st December 2020, 04:00 AM   #11
camplo is offline camplo
whats the latency on this, using this and whatever else that comes along with the process, vs MiniDSP?
Old 1st December 2020, 06:17 AM   #12
hollowboy is offline hollowboy  Australia
Originally Posted by anchorman View Post
Is there an easy way to cut a mini-DSP unit out of the picture for making an active digital crossover <snip>
I already have computer and sound card, was looking at saving myself buying an extra piece of hardware for now, but allowing some projects to go forward without having to buy more stuff at the moment.
The easiest, IMO, is to do it half-assed, in which case, you don't even need a sound card.
1) make a really minimalist passive crossover: a single cap, or whatever you need to protect the HF driver(s) + one coil for the woofer.
2) measure.
3) use Equalizer APO to edit the signal, so that the output is ~flat.
This worked well when I tried it in a small speaker. Before applying EQ, the raw response was fairly well behaved, but the tweeter was far more sensitive than the woofer.
Probably not good if you have hard to tame drivers, and probably a bit annoying if you constantly switch between outputs (e.g. headphones and speakers) when using the PC.
This edit signature thingy is seriously hard to find
  Reply to this post
DSP for active speaker crossovers using computer and sound cardHide this!Advertise here!
Thread Tools
Digital Active Crossovers vs Passive Crossovers - is there a big difference? AudioFunDIY Multi-Way 20 11th November 2019 03:51 PM
I'm considering active crossovers, and just noticed Thomann's T.Racks 4x4 DSP unit. Pygmy Multi-Way 3 16th June 2019 12:43 AM
Active crossovers - opamps vs DSP Zodiac Analog Line Level 61 4th April 2019 05:00 AM
Running 3+ way speaker setup with only two AMPs & a multi-channel computer sound card camiller Analog Line Level 8 7th February 2017 02:39 PM
Using stereo sound card to create a mono 2 way active crossover kimbo Multi-Way 25 22nd September 2014 12:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
