B&C DCX464 build
B&C DCX464 build
Old 19th September 2020, 09:27 AM   #11
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by LineSource View Post
To Dream the Impossible Dream... an audio point source covering 400-20kHz with both smooth frequency response and smooth phase response.
If you're allowing DSP, I had that done a while ago. 35Hz-22kHz. SPL is limited to desktop levels, but adding woofers below 300Hz would fix that easily.
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 2nd October 2020, 05:47 AM   #12
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by cowanaudio View Post
Any references to read about "Medical research on human hearing warns about multi-driver speakers having the harmonics out of phase from the fundamental."?
Pitch, Timbre, and Source Separation
David Griesinger Acoustics
"Source Localization Requires Separation from other signals and noise. This all depends on PITCH, and the phases of the upper harmonics."
  Reply to this post
B&C DCX464 buildHide this!Advertise here!
B&C DCX464 ErnieM Multi-Way 329 Yesterday 04:11 PM
WTB: BMS 4594 or B&C DCX464 Smitske96 Swap Meet 0 30th April 2020 08:01 AM
Test Bench: B&C DCX464 High Power Coax CD and Horn ElecXover Multi-Way 0 20th January 2020 11:26 PM
What amp for B&C DCX464 rotgg Multi-Way 1 28th May 2019 11:54 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
