I had a quick look and haven't come to a list of parameters. I don't know if you can break down the numbers against a focal code.
Some near numbers on Ebay, is all that's a search engine revealed.
Do you have any measuring equipment, do you have you a friend who has measuring gear?
Failing that how much of a risk do you want to take with building some test cabinets for them.
Wild guess, not the best approach !!!, for starters 15-18 litres with a crossover at 2 to 2.5Khz. As hardly any of the manufacturers design woofers for sealed enclosures these days. I guess it will also need a port to get you some reasonable bass, but leave the port till later depending on your application.
Possibly are they drivers for a high spec car install.
Maybe a picture front and back will get somebody else involved.
