Which 6-7" mid/woofer driver do you consider best for a two way project? If cost and box size is unlimited. 8" mid/woofer will do to.
I was thinking of the same recently. I chose MW19P, as midwoofer offering the right balance of parameters for 2-way. I also used MW16P and I consider it even better midwoofer for 2-way, though with less bass extension. Both sounded very good.
Seas W18 Nextel is also very good, it has very smooth FR and is easy to work with.
Recently I noticed SS 18W/8542-10 in new Troels 2-way project, very nice FR too.
Here are my thoughts on midwoofer for 2-way, very briefly:
Illuminator - 18WU, I see it to be more woofer, but actually it could be nice in 2-way.
Ellipticor - I would like to see some 3rd party measurements first.
Accutons - C173 series, I do not see the value here, no hands-on experience. Ferrite models have quite poor distortion. Neo models are quite ok in that regard.
Seas W18 Magnesium - together with Bliesma in WG and crossed ovet at ~1k it could be very good.
SB17xxxx - very nice measurements and value, especially NBAC models. I used 2xSB17NBAC on the bottom of 3-way and it was good for the price, though it was little bit one-note bass. Soon I will have SB17CAC/Seas DXT 2way, LR4, very nice horizontal response, I am curious to hear it.
Audiotechnology - no experience, the lack of measurements keeps me off
Dayton ES180xx - probably very good woofer, but I do not expect good distortion above 1k
Vifa NE180W - overall very good performer, very low distortion
SS 18W revelator - on paper very good option for 2-way, but I have read some reservations to its sound on the midrange
SS18W Classic - some of the family I find very suitable for 2-way. Often assessed as warm sounding.
Morels - no comment.
Wavecor WF182BD03 - nice option for 2-way.
Conclusion: the only flaw of MW16/MW19 is cone-surround resonance. For me this is the least compromise from the group of other options.
The Premios 7" ES180TiA plus a TLabs carbon dome tweeter (back available baed on thread last week on here by Wolf) seems to get good writeups.
http://meniscus.lightningbasehosted.com/wp-content/uploads/2017/11/Premios-Writeup.pdf
Premios | Parts Express Project Gallery
Measurements of the previous version here - Test Bench - Dayton Audio ES180Ti-8 7” High-End Midbass Woofer | audioXpress
This woofer will go pretty low in a 20l box (f3 - low 30's) and look to have good distortion values.
Ugg10: thank you for ES180 info, distortion looks good and off axis response is also very nice. The only down side will be low sensitivity, at least I remember that from Basta modelling of that midwoofer.
Which 6-7" mid/woofer driver do you consider best for a two way project? If cost and box size is unlimited. 8" mid/woofer will do to.![]()
Depends on what sort of bandwidth (both for low freq. extension and upper freq. extension to crossover to a tweeter) you require and what spl.
One of the best units I'd consider for a cost concious audiophile beside Peerless PPB, would be a Scan Speak P17WJ00. A classic once branded as Vifa.
Satori 7.5" 4 ohm, not the best bass extension but good sensitivity
SS Rev 7" great all round driver when used correctly
Seas curv or Nextel
ES180ti in a MTM
Or wait for Satori Textreme
Seas curv or Nextel
ES180ti in a MTM
I'l put in another vote for the Satori drivers. Excellent performance at any price. At the price they can be purchased it's a no brainer.
Thanks for the list of drivers!
I think s-s 18wu looks so cool so I want to get my hands on a pair, but performance seems not as high as the look and pricetag suggests, and i can not justify buying drivers on looks only.
I have a pair of satoris mw16 but I prefere the sound of the sb17nrx, satoris sounds a bit harsh to my ears, sb17nrx sounds more relaxed.
When will textreme be released?
Have you considered the Scan 18w/8531G00? I used it in a 2-way, the Brioso, with a T-Labs N26CR2-A alumina ceramic tweeter crossed at 2.1 kHz, and very recently as a woofer in a 3-way, the Cornetta, crossed at 650 Hz to the 2" dome midrange in the Morel TM4055-8 dual-dome driver. John Krutke (Zaph Audio) also thought the 18WU's price tag didn't justify itself and wasn't really any better than the Revelator 18W. For a lot less money, the SB17NRX is a really good driver and a good value.
Paul
Paul
18w8531 do looks good, but i have heard these lacks resolution and that has hold me off. But i am very tempted to try out the 18wu, maybe it is like with these as with diamond tweeters, they might not look that good on paper but the sound they produce is nothing but breathtaking 🙂
Has anyone tested the Morel TSCM634 6" Titanium Supreme Carbon-Fiber Midrange?
Even though it is a midrange, Madisound claims a respectable F3 of 73-Hz in a sealed box. The frequency response is good to 3 kHz with smooth off-axis roll off.
Price is a little out of my range, but would be curious to real-world measurements.
Morel TSCM634 6" Titanium Supreme Carbon-Fiber Midrange: Madisound Speaker Components
Sorry, did my search again and found this site: Measurements and compare | HiFiCompass
I used the TSCW636 in my Cecropia Supremes, main difference is W is overhung and M is underhung. Measured HD in the midrange is really low. It is amazing how clean this driver sounds.
Later,
Wolf
Later,
Wolf
i think too ,
Or Scan Speak 18WU / 4747T00
A is good driver? midbass performance ?
- Best 6-7" mid/woofer driver
