We are looking to build new studio mains in our recording studio. I have been looking at the Acoustic Elegance TD18H+ with apollo opt they will be paired up with BMS 4594HE 1.4" coaxial compression driver in MTM form.We are not very limited by size of cabs but would like to stay around 5-7cf. These will be built in modular form so sep cab for each driver. We will be crossing over at 450-500hz would be best guess as of right now. Our room is about 22x28 or so. My question is do you guys think the AE drivers will be the best solution? I was looking at Faital Pro and B&C for sure. We will have subs in the room also we want these mains to get down to 35hz for sure and have lots of output. I want be sure before I purchase 4 of them 🙂
The best solution is a complex goal no engineer could ever arrive at with as few information as you have provided. AE drivers are specified to endure 1000W without any measuring standard being mentioned, unlike the professional brands. I would not bet on AE vs. pro brands in terms of robustness. Your AE units could get to 35 Hz vented at -10 dB.
Hi. I've built horn systems for 15 years...and experiences in AE and CD's.
The 450/500 sounds too low for a 1.4 inch format.
I think you should aim for 500/600Hz using a two inch format.
Regards.
Andrew
Regards.
Andrew
A good alternative to the TD18H is BMS 18N862, a superb driver!
Up to about 400hz I preferred this vs AE TD15M for SQ, and that is really saying something as the TD15M is a much better midwoofer than TD18H.
+1
BMS makes great woofers. I have no problems running my 15N850 up to 600hz and maybe even higher if needed.
Still think the AE would be the better choice in pure SQ but I doubt some can't tell a difference.
Regards.
Andrew
That driver is recomended xover is 300hz so i fig we would be good at 450-500. I have also been told by many to stay away from the 2" drivers
I am only asking about drivers not trying to get someone to engineer anything 😀
Thanks for the info its always good to have someone who has actually heard some of the woofers and can direct compare.
+1
That is so true.
Attachment shows BMS 18N862 (yellow) vs AE TD18H+ (grey), both in 6cf vented encloure tuned to 28hz. The BMS typically has 4-5dB more output in the lower bass range, and has 35% greater xmax. So for the lower bass, BMS is the clear winner.
The Faital 18FH500 has a very small xmax, only half of the other two.
The purpose is Monitor not heavy PA for big audience. IMHO the 18FH500 should work quit well
lower RMS, lower Mms, lower Le, etc.....
VC inductance for the Faital is almost twice that of the BMS and 4 times the AE..
Why do you consider lower RMS to be an advantage?
Also has no demodulation rings like AE and BMS to lower distortion.
Yes it looks very good but just checked specs and it says it will only play to 200hz that maybe a problem we need xover around 450ish
Ricci at Data-Bass tested this driver with very positive results, and said this about LP crossover point;
"When combined with the light moving mass this gives the 18N862 a very nice top end, which should be useful up till at least 400-500Hz. It would make a great woofer for a large three way."
Here is the link to the test;
dB v2
I have used this driver myself with very good results to 500hz, crossed over to a 2" CD.
It is primarily intended as a subwoofer driver with its 25hz fs, I guess thats why BMS says 200hz LP.
But very good characteristics in other parameters also makes it work very well at least an octave higher.
dB v2
I read what Ricci wrote at Data-Bass and also noted the mass is very high. It does look really nice in the modeling. Please remember there will be at least 4 subs in the room also so 600hz-50hz would be the most important range for these.
Excuse me in advance for my stupid question but, why don't you use a very low Z motor in order to have a very low Le please ?
- Acoustic Elegance TD18H+ vs ???
