Multi-amp thought experiment
Old 11th February 2019, 08:48 PM   #11
Bon is offline Bon  Australia
Originally Posted by Bon View Post
One thing I experienced is that clipping the woofers is easy to do in active mode
What I meant to say was, clipping the woofer AMPS is easy to do. The sealed woofers can handle plenty of power, it's the power amps that can't supply the grunt (Hypex UCD400). Bigger amps like my Emotiva XPA Gen3 are fine but are way overkill for mids and treble, and anyway you want to use your smaller Rotel.
Old 11th February 2019, 08:56 PM   #12
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Yep Years ago I had the small Rotel stereo amp, I traded it in on the 1070 very quickly; but I did and still do have big and inefficient woofers, but yes I was looking for a solution that meant keeping using the Rotel 4 channel stereo amplifier
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 12th February 2019, 05:37 AM   #13
hollowboy is offline hollowboy  Australia
Originally Posted by Moondog55 View Post
What can I do with a small cheap DSP and 8 * 40 watts? At my first thought that isn't much for bass but that 40 * 4 is equal to most 150watt power amps I've ever owned and those never seemed shy of bass power.
Idea [1]
40 watts could be plenty depending on your goals.
Dude A wants to get a system that's -3dB @ 20Hz. Solution: high Xmax woofers and lots of power.
Dude B wants to get the most out of 40 watt amplifiers. Solution: more efficient woofers, higher -3dB point.
Idea [2]
lots of channels = lots of flexibility.
Dude X builds a simple 2 channel system. It is positioned for imaging, not for LF gain. Dude A uses 200 watts / channel to get satisfying SPL.
Dude Y builds a 2 channel system and adds distributed subs. Several subs are placed in high gain locations, getting a +9dB room boost. Dude Y only needs 25 watts / channel to get satisfying SPL
Idea [3]
use the best of both - flexibility and power..
Use multiple 40 watt channels AND a single large high powered unit, for a multi sub system.
2 x 40 watts --> L satellite
2 x 40 watts --> R satellite
big plate amp --> subwoofer
...and you'll have 4 x 40 watt channels left over. What to do with them?
Well, imagine you want your single big sub to be loud & smooth from 20-100Hz, but (after experimenting with sub positioning + room tweaks), you have deep nulls at 55Hz, 75Hz and 90Hz. Big nulls are hard to fill with EQ.
In this case, you could add four mini subs to fill in those nulls. 40 watts = no problem, since filling in a 55Hz hole is a much easier task then going flat to 20Hz.
This edit signature thingy is seriously hard to find
Old 12th February 2019, 08:38 AM   #14
LineSource is offline LineSource  United States
LineSource's Avatar
Whatever is going to happen will be in the context of the drivers I have in the shed and on the shelves ... I think I prefer to tinker than do straight builds but I have the need to build something big soon
Can you create an inventory of your available drivers?
Does your DSP have 2 or 3 or 4 independent outputs per speaker?
T-M-- --WW
DSP_woofer: drives both inputs to two amplifiers, each connected to one (4-ohm?)woofer. Ported woofers are more efficient than sealed woofers.
Amp1 --> woofer1
Amp2 --> woofer2
DSP_midrange: drives one amplifier connected to one (4-ohm?)midrange
Amp3 --> M
DSP_tweeter: drives one amplifier connected to one (4-ohm?)tweeter
AMP4--> T
Old 12th February 2019, 09:51 AM   #15
chris661 is offline chris661  United Kingdom
chris661's Avatar
I think you might be surprised at what 40w will get you.
I tried bringing my PA system into the house one day and found you could make things rattle with a pair of 15"s being fed less than 50w each.
4x 15"s each with 40w would be rather loud, so long as you don't aim for 20Hz.
Remember Hoffman's Iron Law - small, efficient, low bass - pick any two.
In your case, I'd pick a LF cutoff of, say, 40Hz and mess around with the other two.
Chris
Old 12th February 2019, 10:22 AM   #16
T-M-- --WW
Great minds think...alike...sometimes. Drivers from top down; SB12NRX25-5, SB26ADC-C000-4, SB15NRXC30-8-UC, SB23MFCL45-8. Awaiting cooler weather to permit spray painting. Woofers are reaction-force-cancelling by threaded steel rods. Height approximately 1.3 m with tweeter at ear height in listening chair. Crossover is modified 10 channel MiniDSP through studio grade 192 kHz, 24 bit studio grade AD/DA converter. This is my attempt to downsize from 150 kg monkey coffins that I can no longer move unassisted.
Old 12th February 2019, 10:40 AM   #17
Moondog55's Avatar
I suppose I should Insurance purposes and all that
A lot od cheap some good some very good but all older than 10 years in storage, it being a long time since I have made anything
Old 12th February 2019, 11:25 AM   #18
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
SB23MFCL45-8
What's the sound quality like on that woofer (I'm looking at the 4 ohm version)?
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 12th February 2019, 12:07 PM   #19
00940 is offline 00940  Belgium
00940's Avatar
Knowing what you have, especially wrt woofers, would really help to narrow down options. I really like the satellites plus small subs idea but if you don't have the drivers for it...
Knowing the intended use and the size/shape of the room would also be a big plus.
All that is excessive is insignificant. Talleyrand
Old 12th February 2019, 05:56 PM   #20
Build quality is exceptional, huge double magnet and roll surround. Used as a sub-woofer (< 100 Hz) there is nothing of similar price/size to touch it. It sounds good even used as a front firing woofer up to 250 Hz. I did not know there is a 4 ohm version. Since I parallel them, 8 ohm suit me better.
Multi-amp thought experimentHide this!Advertise here!
Computer speakers Thought experiment help Moondog55 Multi-Way 26 22nd February 2013 06:31 AM
The Chinese Room Thought Experiment thadman The Lounge 43 19th December 2012 11:53 PM
Just a thought experiment… no1herenow Multi-Way 29 23rd January 2012 06:35 PM
Who Wants To Be A Millionaire? (a thought experiment) thadman The Lounge 10 11th May 2011 09:54 PM
BIB thought experiment Brisso57 Full Range 3 27th January 2009 03:13 PM
Copyright ©1999-2019 diyAudio
