The problem you will have working from just the picture is:
1. The value of the inductors is not known.
2. The value of the two capacitors at the lower left is not known.
3. The connections between the parts is not shown.
The missing information is likely to prevent a successful clone.
SEAS 6.5" woofer
SICA 1" driver (Not 100% sure but similar specs)
A video showing the back of the speaker, the in-wall version.
I plan to build the box myself.
Procella Audio maybe are using custom-made drivers from Sica and/or Seas, which may look exactly like the mundane, available to the general public drivers, but with different parameters. Or maybe not. Bottom line: your friend can not judge that just from the look of the drivers.
And what about the P6V horn, which does not look like a Sica Q07020A horn, or any I can thought of?
- Make a crossover from picture as reference.
