Not sure if this is the right forum but I'm looking for someone who can machine and assemble speaker cabinets for a prototype pair. Either based in the UK or ships to the UK. Panels will be MDF. The only caveat is that they can take a 3D file from Sketchup - I'm having a nightmare exporting DXF and DWG which most CNC shops in the UK seem to need.
The panels need machining both sides and a couple of edges require a specific angle.
Cheers
Cheers
It might be worth having a chat with these friendly people.
Boardcraft | CNC machining, laminating, bonding & joinery
When I have spoken to them they suggested they could work with all sorts of file types, and failing that would draw it up from a sketch for a small cost.
They are in St Neots in Cambridgeshire, I think definitely worth a try.
