Guess so. They already had massive amounts of sensitivity before these new drivers too.
go check it out: Compression Drivers of Beyma
The impedance measurement for the Beyma CD11Nd shows two large peaks(~950Hz and 1900Hz), and one small peak(~3100Hz) in the listening range.
The Faital HF108 1" compression driver, which I own, has only one large peak(~680Hz), and one tiny blip at 3300Hz.
For the CD11Nd, what construction generates the extra impedance peaks?
Several plastic domes are glued/heat_set to a high temperature Kapton voice coil former. I wondered if the 3300Hz blip on the Faital HF108 is generated by this construction.
