Hello Bergarth
Don't make a 'series' connection based on what you've read.
Let's look at your amplifier;
Solid state amp as a voltage source. Lower impedance speakers yield more output. Therefore parallel connection gives more output. Try to match their output to your woofer.
Solid state amp as a current source. There are a few SS amps that behave more like tube amps than SS. Measure both outputs, series vs parallel.
Tube amplifiers are almost always current sources. Having done a series connection for two 'woofers', I can tell you it was spectacular.
Through the years, reviewers have stated; speaker A sounds better with tube amps, speaker B sounds better with SS amps. Two different animals.
The output impedance of your amplifier slightly affects the crossover.
Experiment, experiment, experiment. The joy is in the journey, not the destination.
I picked series because the projected response was smoother than with parallel, and in PCD for Flat as i can get response it shows i need to run the two mids in series and reversed polarity, So thats a first for me lol Wondering if i invert polarity to the one mid or both lol
