Goodmans maxim, BBC found alternative replacement, what is it....
Goodmans maxim woofer, BBC found alternative replacement, what is it....
This pair of ex BBC maxims were for sale on eBay recently. I noticed that one of the woofers had been replaced. The BBC, must have confirmed by measurements it's suitability as a replacement, it must be quite a similar driver.
So does anyone know what it is. I have some Double maxims I am rebuilding and on the look out for (obtanium) woofers........
or any other similar ones that may work for that matter?
thanks
Hi, I don't recognise it as a Goodmans, not that I know everything. I think the original maxim woofer is a development of the old midrange used in the magnum for example, at least I am pretty sure it uses the same cone, "just" with a long travel magnet and suspension coil. I think the dimension 8 mid range is another variant. the Goodmans has a flared cone, where as this one is straight sided. Looks more like a Philips or Celestion to me.
mystery solved... it is a later version. More unobtainium.
I am going to graft some dimension 8 woofers in to my very tatty double maxim boxes, they are a little bigger with a steel basket and probably the wrong impedance, but seem a close family member.
The BBC report on the Goodmans Maxim is still available:
http://downloads.bbc.co.uk/rd/pubs/reports/1965-09.pdf
2kHz 2nd order crossover to cone tweeter. 4.5" paper bass with rubber roll surround, we'd guess. 5L closed box.
Wonder if these Peerless 830870 polycones would fit? They look suitable for closed box. You might investigate the crossover, and whether the basses are series or parallel wired, which affects impedance greatly.
https://www.falconacoustics.co.uk/drive-units-1/peerless-830870-midwoofer-hds-range.html
The tweeter in yours looks like that ancient Philips AD0160 mylar unit that Troels Gravesen evaluated, so the crossover must be nearer 3kHz: http://www.troelsgravesen.dk/WWDT.htm
The more modern take on this sort of thing, which might be more satisfying is this: http://www.troelsgravesen.dk/VifaPL14WJ-R2604.htm
