Has anyone used the Beyma 12LX60V2 woofers. I would like to use 2 of them in a cab for the bottom of a three way crossed over at around 400hz,
or one 15LX60V2 also crossed over at 400hz the horn loaded BMS 2" mid.
What do you think will be better combination, 2 x 12 or one x 15 per side?
Oh I am currently using the Faital pro 15PR400 in a 150 litre cab. It is wonderfully musical, but thought I could get considerably more bottom end with either of the LX series woofers.
You can look there for the slab12, which is the 12Lxv2 combined with a 12 inch tractrix horn from stereolab...
Strassacker: Lautsprecherbausätze (Lautsprecherboxen-Bausätze) und Lautsprecherlösungen
It also shows that the driver is suitable for two way setups up to 1-1,3 khz than there is some nasty resonance.
Swany.
Swany.
