It's a two-way system so this forum should be fine.
This combination is a bit strange. Although Fostex FE126E has better bass among full range speakers, bass is still its biggest drawback.
Fostex FE126E's high frequency should be fine, I've tried to pair Fostek FE127E (a cousin of 126, maybe) with a tweeter through a Linkwitz Riley crossover, bi-amping but I don't see any improvement in sound. Probably just my taste or my ears cannot distinguish between the two setups.
Hmm interesting driver choice. As I see the virtue is a higher sensitivity (approx 88db) than typical from a small speaker like this(usually around 84db)
HOWEVER this only achieved with speaker against a wall ( "bookshelf" ) and likely still a lean bass so I see no advantage.
All the coils on the x over board in same direction...........
The FE126 really wants to be in a horn to have any chance of decent bass. Adding the tweeter and XO is one way to deal with the HF problems. But that XO will get in the way of what people like about this driver.
It should also be noted that the FE126e has not been available for a long time. The FE126En now sold is probably different enuff that the XO and bass alignmnet would need to be revisted. I would suggest looking further.
dave
dave
Thanks for the replies guys. I had only asked because I happen to have both of the drivers and was wondering what to do with them.
I have lots of experience with Fostex drivers and actually have a pair of horns with the 126 already...
I am however not a big fan of Troels tendency to go overboard on the crossovers....
I think I will give it a go and report back.
If I dont like it I can always do something else with the drivers.
I am after a desktop monitor to go with my laptop and I think these just might do the trick...
If You are going ahead, then you might consider this box to put it in. Smaller and better bass as far as it goes… it doesn’t try to extend the bass extension below what it is really capable of. Designed to be a centre channel for those with FE126 Frugel-Horn Mk3.
http://www.frugal-horn.com/downloads/FE126E-smallCentre-131017.pdf
dave
dave
The Von Schweizer uses the FX120 which is quite a different beast than the FE126.
dave
Sure, but inspiration is pretty clear, Troels uses same tweeter and in a partsexpress cabinet .....
I personally really liked this tweeter in the axis voicebox, I thought that this Australian speaker was one of the highlights of the last THE show at Newport, small two way paired with a 5" peerless nomex driver
I don't understand planet10's design yet, it's like a bass reflex design?
In the strictess sense it is a BR. But the long high ratio slots add resistance which pushes the box towards aperiodic and makes them more tolerant of dynamic changes in T/S parameters. It puts constraints on the bass alignment in the sim, and puts limits on how low the tuning can be. When doing a sim i look for a specific shape curve knowing from experience the effects of the radical shaped vents. One gets very fineesed articulate bass that goes only as low as it goes.
We have done literally into the hundres of designs based on this “miniOnken” alignment.
dave
Fountek+ FX-120 combination
Just the FX-120 makes a good small speaker system. Minimum ofabout 10 litres thouwillmake it too large for some desktops.
dave
I have previously had a pair of FX120... They were quite nice for the size.
I am quite curious however about the ribbon + fullrange combo though.
Most all of these smaller fostex drivers are pretty ragged above 5k and the ribbon should have not only the sensitivity but a super smooth response that high which I am hoping will compliment the fostex well.
- Troels 2-way with Fostex 126 and Fountek Ribbon tweeter?
