Your projects for 2018?
Old 24th December 2017, 03:28 PM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default Your projects for 2018?
Always curious to know what people have planned!
My projects will mostly be finishing half finished ones Your projects for 2018?
Ok two I have planned
An MLTL using the Rev 18W/4531 and viawave GRT145
A v small standmount with SB ceramic 5" and viawave rt850.
Old 24th December 2017, 03:44 PM   #2
lsiberian is offline lsiberian  United States
I plan to build my next 3-way project. It will be a fully bipolar speaker sealed speaker that uses CLD and a dense red oak bracing matrix.
Currently I'm leaning towards a build with the Dayton AMT tweeters, Dayton Dome Midrange(already own), and the Dayton RS-225. I'll be using the Minidsp as the crossover and my Dayton MA1260 as the amp.
I'm debating using a template rather than a jasper jig for cutting and recessing. Anyone who's used the jasper jig can tell you it's very tedious for more than a couple holes. Cutting the same holes six times gets very old and takes forever.
It will be the first build I get to use my table saw for everything on.
Old 24th December 2017, 03:47 PM   #3
Ugg10 is offline Ugg10  United Kingdom
First job is to finish building my 1968 Ford Anglia 105e.
Then I will need a new project so thinking -
Affordable (relatively) Compact 3 way monitor - looking at Dayton RS180p-4, TB W4-1337SDF plus SB 21RDC - based on slightly cut down Holtz Statement Monitor (around 18-20l) but with front slot port and running the Statement tube mid cavity. Running fully active with minidsp (x2) and one amp per driver. I have two Rotel rb850’s to be used for bass in bridged mode, looking for possibly an Arcam Delta 290P or Audiolab 8000P for the mids and possibly a valve or class A for tweeters. Looking for a tight bass, revealing mid and sweet (not harsh) top.
Then I have some plans for my old AR EB101 turntable!
Old 24th December 2017, 04:50 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
Re-doing the living room stereo. Currently I have a pair of active monitors which I've modified to have a 3.5mm jack input. I don't have a preamp or anything like that, so I feed them from a laptop. I'm not quite happy with the monitors, so I've decided to start afresh, with these:
An unlikely monitor - FE166En, small box, solid-state amplifier
Amplification will either be a decent integrated HiFi amp, or a silly-big PA amp depending on what I fancy.
I'm hoping for a detailed sound where you can hear more "into the mix" compared to the current speakers.
Chris
Old 24th December 2017, 05:21 PM   #5
norman bates is offline norman bates  United States
norman bates's Avatar
I'm happy with 6db tweet plus wide range (think seas a26 kit but with eminence b102 and morel cat378).
But i miss the bass feeling of double 15's crossed at 750hz.
Need to resolve this.
Old 24th December 2017, 05:37 PM   #6
Fernando R is offline Fernando R  United States
A small 30 liter tower. Debating whether full three way with SB29RDC, 5" mid and Satori MW19 7" woofer or a three 5" woofer design Andrew Jones Elac F5 style. The 5" driver in either case would be the Scan 15W4524T.
Fernando
Old 24th December 2017, 07:16 PM   #7
KJ_Knowles is offline KJ_Knowles  United States
KJ_Knowles's Avatar
I'm trying to finish a project I intended to be complete by the end of last April, for the 2017 Lone Star Audio Fest. Maybe this year... It was originally going to be a small(ish) form factor, slot loaded open baffle tower, with BG Neo10 mids and Aurum Cantus AST2560 AMT type tweeters.
Before cutting began, the reality of how unsuited my listening room is for dipole radiated LF (no practical way to get a decent distance from walls) resulted in that design being stillborn. I changed it to a hybrid design. Sealed enclosure LF, open baffle for the shorter wavelengths. Mostly just playing around with "maximum surface area/minimum form factor". System will be active, using FIR filters.
I'm building an LCR set and have fabricated and veneered the LF bins. I'm currently cutting woofer holes...and more woofer holes...and MORE woofer holes (for HiVi M8N's). 18 woofer holes is a bunch of router passes...it feels like a career! I have cut the front baffles and marked the driver locations, but have not begun finishing or routing driver locations for those, yet.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 24th December 2017, 10:20 PM   #8
Neat.
Old 24th December 2017, 11:52 PM   #9
mordikai is offline mordikai  United States
Your projects for 2018? Send a message via Yahoo to mordikai
Large 3 way with satori tweeter, satori 19mw, sb42flh woofer. Gonna copy the large ATC look. Probably 20" baffle about 6 cu. ft. Will
Probably start with active version on the woofers and maybe an all passive for fun.
Cutting wood next weekend.
Old 27th December 2017, 02:36 AM   #10
Hoping I make it this year. It was a lot of fun when I went last time.
It would be cool to have my speakers finished by then too!
Your projects for 2018?Hide this!Advertise here!
New project for 2018! ygg-it Chip Amps 5 13th December 2017 09:24 AM
Need help for 2 projects bcbud3 Multi-Way 8 10th October 2016 05:26 PM
any new projects ? norman bates Wild Burro Audio 6 19th July 2012 05:37 PM
One of my projects Brion55 Instruments and Amps 3 3rd July 2005 10:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
