Hi, I'm still with the crossover without sounding as I should have, I've built it by multiplying the value of the capacitors and dividing the value of the inductances and I think there is distortion in the media.
If you will design it for me, you will pay for your design. Cheers
Unfortunately a crossover can not cure driver distortions. I think your 8 ohm units might also be slightly damaged. Did you buy them second hand for little money?
Anyway, my crossover proposal is in post #20, and I can't do any better.
The straight way to switch from 8 Ohms to 16 Ohms is to replace the diaphragm/voice coil. I've done this on four of my ATC 70-150S. This is a very simple operation you can do at home.
You can purchase the part straight from your ATC distributor (don't know where you are but I've done it here it France). You just have to provide the S/N of the drivers you want to remplace the diaphragm and request for 16 Ohms instead of 8 Ohms.
For me it has been about 280 euros per part.
