kicker ZR1000
i have a zr1000 with a power supply issue. amp powers up fine and plays fine at low volume. whey you turn up the volume then it goes into protect. upon futher testing the rail voltage drops on one side only. i have the input set to full range and have 8ohm speakers connected. i checked the power supply fets and the signal to them. Attached photo shows the output from the power supply driver.
SG3525ADW. thought it might be a faulty driver so i replaced it and no change. also changed the timing cap and still no change. any ideas?
the PWM circuit before and after. I'm pretty sure that the signwave is supposed to be a square. something is either weak or leaking or mayby open. Not sure.
You have two outputs from U1, Pin 11 and 14. Do they both look similar to the photo you post?
Post a photo of the waveform on pin 5.
Check the values of R6-4.99K ohm, R7-150 ohm and check C3-47uf with an ohmmeter and capacitance meter if available.
I believe C2 is a .0047uf cap. Make sure that C2,C3 and R6 are connected to chassis ground.
i have pulled the rectifiers on both sides. wanted to see the waveform with out a load from the amp. i will post the pics soon. the wave form was the same on both. i did change the cap with 4 of .001 in parallel that gave me the wave form that was shown. didnt get a chance to show the wave before i changed the caps.
I have a second zr1000 here as well. It is now in working condition, so I have something to go on. But I need a schematic with some test points. Was told where to find but forgot where. Old age.....lol
You are never to old to learn!!!
