My first Center Channel Build
Thread Tools
Old 11th May 2014, 07:03 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by FoxGaming View Post
My Max budget on this Center channel is $200
When i was 1st suggesting FRs, i wasthinking you eeded a pair, but a Centre is just 1 box, which means you could afford a more expensive/better FR such as Mark Audio Alpair 7.3, A10p or A10.3.
All of those, and many others, if you spend more are decidedly better. Makes way more sense than buying multiple lesser drivers.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 11th May 2014, 07:31 PM   #12
MITsound is offline MITsound  Canada
MITsound's Avatar
Are you planning to run full frequency, or use a receiver or processor for bass management?
Old 11th May 2014, 08:11 PM   #13
FoxGaming is offline FoxGaming  United States
dave
Ahh that makes sense, the only reason i had planned on doing multiple drivers is because those drivers are rated around 30W max, while the amplifiers i'm looking into are 100-150w RMS per channel. My front channels are very inefficient(but they're also approaching 30 years old) and require 100+ watts RMS to really come alive.
I will be using a receiver for bass management, I'm not sure if i'll be adding a sub woofer to this system yet. It's going into a smaller room approximately 11ft x 12ft so i'm unsure yet if my speakers will be good enough or if i'll be needing to add a sub woofer.
Old 11th May 2014, 09:59 PM   #14
frugal-phile(tm)
planet10's Avatar
...are rated around 30W max, while the amplifiers i'm looking into are 100-150w RMS per channel....
It really is irrelevant.
Get any of those 3 higher end drivers i mentioned,and you could well find yourself planning new mains as well.
dave
Old 12th May 2014, 07:08 PM   #15
dave
Out of those 3 drivers I'm kind of leaning towards the A10.3.
Not sure if I'll be able to get the added thickness by my wife, it will probably end up around 8" tall. As far as sound quality will i be sacrificing much by going with the Alpair 7.3 driver?
  Reply to this post
My first Center Channel BuildHide this!Advertise here!
Thread Tools
The beginning of a tower speaker and center channel build username8611 Multi-Way 19 23rd March 2014 11:57 PM
Statement center channel - who can build the cabinet for me tommarra Multi-Way 2 3rd April 2013 05:14 PM
Building a center channel to match ADS L1290 towers [first build] minibeardeath Multi-Way 0 26th November 2012 02:07 AM
HT Center Channel Build Kahooli Multi-Way 12 15th December 2011 09:14 PM
center channel?? wicho Multi-Way 1 25th October 2008 02:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
