Iv'e got 6 scan-speak units lying around. 4 pieces of 21W/8555-00 and 2 pieces of 10F/4424G00
Thinking of putting them in my test closed cabinet with ~54litres resulting in a Q of ~0,8 for 2x 21W/8555-00 woofers in parallel.
Also considering if I should go with a MTM or TMM construction. For a crossover-newbie, which of these is most likely to be least troublesome in the crossover design phase?
Are there any obvious indications why these units won't work well together, that I am missing?
Best regards.
René, Denmark
Best regards.
René, Denmark
A TMWW would probably give you the best sound by adding a tweeter like the Vifa XT19 or Vifa OX20SC00-04 without a bezel frame using a LR4 Xover ~3Khz. Adding a tweeter will both provide clean extended treble to 20Khz, and an improved controlled directivity function by removing early beaming from the 10F/4424G00 if it was used full range.
The Sony SS AR1 is a good mix of engineering and style, of form and function. A tall, 13" wide cabinet will have a baffle step ~ 300-350Hz. If the 10F/4424G00 Xover is at the baffle step frequency ~3?0Hz it will not need to reduce SPL for the baffle step compensation, and allow a simple, clean Xover circuit. The two 21W/8555-00 can supply the 4-Pi baffle step SPL energy, and this also allows a simple BSC room tune resistor.
A speaker worth keeping... a speaker you can use for measurement and Xover study.
As a start-up for a 2/3-way test speaker, for your drivers, have the FR (calculated as 92.1 dB/2.83V/m) in a small sealed enclosure of 1L (ok) to 2L (maybe to big) with a 150 uF cap and the woofers in parallel with a 1.2 mH coil, (94.4 dB/2.83V/m for 2Pi and 90.4 dB/2.83V/m for 4Pi), just as a reference for initial crossover components. Just an idea to what you are doing.
Thanks for the answer guys.
LineSource: Yeah I am aware of the fact that adding a tweeter would perhaps improve the overall sound, but since I am a newbie in constructing passive crossovers, I think I'll go with the 2-way concept for starters and see if I can make that work whilst gaining some experience in the progress. The current test-cabs are only 10" wide, giving a baffle step of ~460hz. Will that be too high for the woofers even with a LR4 filter, I wonder? They do seem to cone break up rather early...
Inductor: Wouldn't it be wiser to start of with a higher order crossover? My guess is I'll run into trouble with an LR1, at least with the woofers.
Will the 10F sound harsh in the top if I don't implement a tweeter to take care of the high frequencies?
Face: Thanks for the offer to help with the crossover mate, it is greatly appreciated. I will write you if I decide to fit in a tweeter in the construction, though i don't know yet which one it will be. (Probably an SB-Acoustics tweeter, good value for money it would seem)
I do not think you will experience woofer cone breakup with a 460Hz LR4 Xover. The SPL graph for the 21W/8555-00 looks flat and well controlled up to 800Hz. Since 460Hz is in the critical vocal range, you may want to also experiement with a LR2 slope which spreads out the handoff between woof-mid.
As the physical size of the 10F/4424 cone starts to create beaming, more acoustic energy is spread into the reverberant room, and less acoustic energy is directed at the listener. Most listeners would note a reduction in clarity and dynamics. To get the flattest high frequency SPL from the 10F/4424 you should experiment with a 30 degree off-axis rotation wrt the listener.
This ratio of direct vs. room acoustic energy is part of the religious choice between horns(9db direct gain), dipoles(4.77db direct gain) and conventional box speakers.
I have a computer equalizer in my system, and a 20db drop at 10Khz(SPL graph) is very noticable. You could design and construct a box such that you can add a dome tweeter.
Makes me think of the originals 301/601
(images sources below for reference or fair use copyright)
Bose 301: ?udiozavar.com Bose 301 -?????
Bose 601: bose 601 in good shape - AudioKarma.org Home Audio Stereo Discussion Forums
- 2x 21W/8555-00 + 10F/4424G00 - Will it work?
