My speakers are smaller than the Summa but I wonder how close these sound compared to the full size Summa (minus the LF extension in the simulations). This is 8 inch freestanding over 8 inch woofer. They miss the mark on the polars by apprx 300Hz if I read the Summa polar data correctly. My simulations are also made at 20 degree listening axis/toe-in.
Something I've noticed is when the speakers are positioned on the long wall of a rectangular room (with unequal side wall distances) the soundstage is only as wide as the speakers. When the speakers are placed on the narrow wall with equal distance to side walls the soundstage is as large as the whole front wall. Yet neither imaging nor intelligibility seem to be damaged despite the larger soundstage width. I also toe them in like Geddes recommends for his speakers. Even though I have extremely limited listening experience I'm convinced Geddes' theories about waveguide sound and positioning are solid => if my speakers are close enough to his that I'm hearing what he gets to hear. This type of waveguide speaker set up the way Geddes describes sounds exceptionally good to my ear.
I have no doubt other designs and setups are good - possibly superior - but Geddes' waveguide way is extremely good when sitting at normal residential listening distances. Of all the choices people have when they setup a system I would recommend this as one of the good options among many good options.
Here are the Summa 20 degree real life non-simulated measurements
Ah OK. There's a lot of misinformation about the Klippel drama on ASR
ASR has become a very toxic place thanks to some core members. Disinformation and negativity typically spreads like wildfire there with little interference from the mods unless it’s something bad about the site leader. it’s really weird behavior from adults.
Anyway, glad we got the M2 thing cleared up.
Yeah it's a bummer. I really and truly think you're doing great work and your dedication to the science is admirable. One of the things that I generally like about scientific forums is that they tend to be free of the drama that plagues all the other forums.
SIDE NOTE:
In case people are just thinking I'm being sycophantic:
Of all the projects I've ever worked on, the 2nd time that I put Unity horns in a car was one of my projects that turned out particularly well. I did something somewhat radical, which was that I put the horns up on the dash, and I used the windshield itself to extend the horn mouth. The idea that I had was that if you got the first 8-12cm right, the rest of the horn could be less than perfect, but it would still (mostly) work like a horn.
This was quite a bit different than what most horn cars were doing in the 90s and in the 00s; in the 90s people were putting horns under the dash of cars, largely because it was a way to put the speakers as far away as humanly possible. In 1995, there were no affordable DSPs and the most famous horn car was owned by a multimillionaire who poured tons of money into his car. He'd literally sold his Ferrari Testarossa to build a car stereo: https://www.racingjunk.com/news/richard-clark-the-buick-grand-national-guru/
Maybe I'm daft, but I got the impression that nearly all of the horn cars were mostly focused on copying Clark's formula, and while it was a very good formula in 1988, by 2004 we had some other options available to us. Particularly because compression drivers were getting very small and DSP was getting very cheap.
So I took the first stab at it in 2006 or so, and then I did it again in 2008, and it was the second design that really shined. I really and truly think it's one of the most successful projects I've ever done.
And then Erin did basically the same thing with some Kef coaxes and my mind was blown.
He's super smart and there's a 99% chance that he came up with all of it on his own, but I got the impression that he was just about the only person that grasped the idea that you can take the entire windshield and turn it into a waveguide. One of these days, Ford or BMW or Mercedes might wake up to this idea, and it's kinda boggled my mind that we don't see this more often:
In this case, as opposed to long wall, are you sitting further away?
I am not being cynical ... I highly doubt that lol! The designers of Jeep Grand definitely noticed, I have drivers buried in the same corner, turning the corner into a waveguidegot the impression that he was just about the only person that grasped the idea that you can take the entire windshield and turn it into a waveguide.
Array 800 ? 8" + 175nd 1" CD. If I were to build a high output speaker today, it would be a Synthesis 1400 type with 8” woofers instead of the 14” they used.
Array 1000 used a 10".
Actually the 1400 woofers from JBL do better then most in this regard already.
Notice the turncated frame, and how little space there is from the surround edge, to the edge of the frame.
Something not found in most drivers.
But I digress, large systems like the M2 don’t fit modern lifestyles and IME narrow baffle systems image much better. If I were to build a high output speaker today, it would be a Synthesis 1400 type with 8” woofers instead of the 14” they used.
Just purchase a pair of 590's when they go back on sale.
Rob
I would say the QSC K.2 series are unreliable. A friend bought a pair new and both broke within a year. Many people complaining about reliability. Many pages of common issues in the service manual. I found a blown diode D51 but at first i could not find the type as it was simply marked with a general code KB which seems to be a type of zener. I finally found the actual diode code which is a schottky diode RB751S40T1. Soon after this a technician called me to propose an entire new module. QSC asked an independent tech to call me. He advised me not to try the repair. I briefly quizzed him on the conflicting diode information but he just brushed it off as revisions. But was it the schematic that was revised or the KB diode that was revised on later models, i'm guessing the RB751S40T1 is the latest revision of the KB was fitted by accident?. How can a schottky replace a zener or vice versa? It seems mistakes were made. I'm still confused. Well the first time one of my friends K12.2 blew they fixed it but it took a month via Thomann he uses it only during the ski season which is soon over. This is why i kicked up a fuss on the QSC form and made it public. Seems this time they proposed a faster solution.The QSC waveguide used here is previous gen.
The current QSC K12.2 are interesting....
They top the spinorama chart, even with the KEF Blade meta according to Pierre's site.
https://www.spinorama.org/
Of course it's too good to be true.... The data is heavily smoothed. And the pattern is of course quite narrow.
Nevertheless, you have to give credit to the effort made to smooth all the potential diffraction points.
He is currently contacting the technician to find out if QSC is covering the replacement module at €413 i think it was. This is also confusing to me. The service manual does advise you to check D51. If it ends up being me making the repair i will also de-solder the fets to check them (power supply switching). There is one 6 pin ic (that switches the fets i guess) and i may need to replace this also, but they do not mention it in the service manual although there are literally pages and pages of things known to go wrong. Seems they messed up with this series. perhaps they will rectify these issues but some direct contact with them would have been nice. Anyway although i have 4 QSC power amps i do not feel good about the k2 series so far. Luckily i do not own them myself.
Also, after reading it seems the frequency response depends on the firmware you have installed and how hard you push them depends on what you can get away with.
- JBL M2 for The Poors
