Looking to make use of some older parts from some Raw acoustics kits.
i have a pair of RAW acoustic OB2x, OB3x and a pair of CSS FR125.
As i no longer use the OBX's or the FR125's (a Frugelh Horn with Alpair 7.3 took there place) i am thinking of repurposing the drivers.
Driver list:
CSS FR125 - x2
GR Research M-130x - x4
GR Research M-165x - x2
RA 104.5 x4
To start with I am looking at building a 2 way with the RA104.5 tweets and the CSS FR125 as wide-range mids mounted in a Parts Express .25 ft/3 curved cab (as I already have them). Then later I may augment the bass by repurposing the GR drivers.
For now, would the FR125 work well paired o the ribbon tweet?
If so what crossover point should I shoot for and should i put any crossover on the FR125 to limit its HF?
Ay advise wold be apreciated!
Driver list:
CSS FR125 - x2
RA 104.5 x4
CSS FR125 data sheet: http://meniscusaudio.com/images/CSS-FR125-data-v3s.pdf
Only specs I could locate of the RA104.5:
Rated impedance: 6Ω
Rated Power: 30W
Sensitivity : 96dB/W/M
Frequency range:1500Hz~40KHz
Dimension of aluminum ribbon: W8.5mm×L60mm×T0.01mm Shape of aluminum ribbon: wave
Mass of aluminum ribbon:12mg
Frequency cut recommended:over 2200Hz
Moving area of aluminum ribbon: 510mm2
Gap Fiux: 0.55 Tesla
Material of mounting faceplate:aluminum,CNC processing, surface with anodizing electroplating finish.
Dimension of mounting faceplate: Φ104.5mm×T4.5mm
Outside dimension : Φ104.5×D84.5
Rated impedance: 6Ω
Rated Power: 30W
Digging out the HT2 XO, i am reminded that it was an MTM.
You'll need to use the HT2 XO to figure out what parts to toss in the HT3, and then you'll likely need to adjust the padding on the tweeter to get the levels right.
Al may hav esome suggestions.
dave
dave
Jared
Send me a PM.
We can talk.These are the original designs for both the HT2 and HT3 were changed with new crossover designs thus the name HT2i and HT3i
Your have other options, in that mix of drivers all depends on what you are looking for.2 way 3way tower bookshelf ect.
Al
Send me a PM.
Al
- 2way with CSS FR125 and RAW RA104.5 ribbon tweet - design help needed
