The tweeter is the Seas Excel T25CF001, the mid is the Seas CA18RFX and the bass driver is the seas CA26RFX.
http://www.troelsgravesen.dk/Jenzen-SEAS-ER.htm
The speaker uses 2 transmission lines with the lower one front firing and the midrange vents to the rear. The finish is a standard 2 stage automotive gloss black.
I don't feel that it would be worth it, to me at least. I couldn't justify the increased cost of the speaker vs higher quality amps or room improvements.
As far as the finish goes I had a new idea right after I finished these. You could bond acrylic to the unfinished MDF or plywood for the perfect finish.
