Members will help you if you post your system/horn specs and elaborate more.
You can look for the original Electro-Voice 1823/Electro-Voice 1823M maybe with the help of e-google.
Anyway in new designs, the Selenium D250-X Compression Driver is also an excellent mid driver.
Selenium D250-X 1" Phenolic Horn Driver 1-3/8"-18 TPI Pro Audio Compression Driver 264-204
