I've had a hard time finding those as well, I even called parts-express to see if they could get them and they can't.
You might try these though, they do a similar job and are actually pretty cool looking.
Connex Ceramic Terminal Strips
Yes, they look rather sexy.I've had a hard time finding those as well, I even called parts-express to see if they could get them and they can't.
Are there any special soldering precautions with those? The photos look similar to terminal strips used in instruments from Tektronix, circa mid 1960's. You were supposed to use a special silver-bearing solder on them, to prevent the metallized connection points from becoming un-metallized. And, even with the proper solder alloy, you had to keep the temperature down and work quickly.
Dale
Dale
I'm not sure if there are any precautions, I haven't ordered them yet. They look pretty solid though, and the ones with the threaded screw posts look like they'd be easy to attach to a wooden crossover board.
