Beautiful Swingin' Speaker
Thread Tools
Old 23rd January 2010, 08:16 PM   #21
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Originally Posted by event horizon View Post
Much like a dog the tail gets the whole dogs body moving,..
Yeah - good point - consequently he would need to suspend the bass too.
This way there is some isolation in "energizing" the floor too.
Michael
Old 23rd January 2010, 09:07 PM   #22
mige0's Avatar
The mid unit of the "PrimaLuce" looks interesting - anybody seen measurements of the Hertz HV-1600 or used it ?
Michael
Old 24th January 2010, 08:53 AM   #23
StigErik is offline StigErik  Norway
StigErik's Avatar
I knew that you would build something like this! Great work, and great inspiration for all of us!
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 24th January 2010, 09:11 AM   #24
mige0's Avatar
With *your* thread you show and encourage us to consequently follow our ideas to the very bottom end – I'm really thankful for the great fun we all have had there !
I'm looking forward with which final rig you'll come up with.
Michael
Old 25th January 2010, 01:33 AM   #25
CLS is online now CLS  Taiwan
Good job, and thanks a lot for sharing
I got 2 questions:
1. Smart and clean solution for woofer! How is the acoustical effect of the gap? Is there any detectable 'leak' on LF?
2. The top-bottom walls of dipole horn seem horizontal and parellel. Would there be internal reflection? (Worrying about the non-flatness of wavefront... )
Old 25th January 2010, 10:11 AM   #26
mige0's Avatar
Originally Posted by CLS View Post
I got 2 questions:
Two good questions but no "real" answer, I'm afraid
Thanx for your kind words.
I have not measured – so I cant tell the accurate difference.
From listening I'd say there isn't too much a difference – I still have my active turn down shelving (!) around 45 -80 Hz in place – otherwise there's simply too much bass (well, in that room)
Also – there still is this physical sensing of the bass through the floor by my feet. Given the exceptional good isolation of swings regarding leakage path through the structure, this tells me at least something
This physical sensation through the floor I like a lot and is something I'm always after – its not that the carpet builds up in waves – but it has to be there – even at moderate levels.
Yes, top and bottom plate of *this* dipole horn are in parallel to simplify building and to keep inter driver distance low.
If we assume ideal flat wave front to exit the NEO3 and enter the horn – well, all vertical pressure points are in perfect balance to each other – so no reflection = "bouncing between top and bottom plate" should occur IMO.
On the other hand, with such a design, there is always the issue of "in-adequate termination" = extreme bending of the wave front = sharp 180deg diffraction - where the top and bottom plate ends.
This issue could be treated either in applying the horizontal contour in the vertical direction too – making up for a standard horn – or by figuring out a lip that provides smoothing the same way as rectangular OB provides smoothing over a circular OB.
As a standard horn isn't an option for me right now (I encourage everybody to give it a try !) I did some investigation in optimizing the lip with reasonable results – in *FR measurement* at least:
NEO3-W in Gaussian Min Phase horn with optimised lips:
NEO3-W in Gaussian Min Phase horn with straight lips:
sadly these improvements in FR measurement do not correlate with sonic impression.
Or maybe I should put it more precisely – flatter FR here is a trade off to increasing group delay – which is not handled easily with simple passive XO.
Bottom line – the straight cut at the end of the horn sounds really good to me – though it measures not as perfect as I would have liked.
Just for comparison
below the Neo3-PDRW (the one with the two inner felt stripes at each side) in the same Gaussian Min Phase horn with straight lips:
Michael
Old 25th January 2010, 11:05 PM   #27
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Default Love it
This is thinking a little outside the box
Great stuff and looks like it was good fun too
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 26th January 2010, 03:23 AM   #28
LineSource is offline LineSource  United States
LineSource's Avatar
This issue could be treated either in applying the horizontal contour in the vertical direction too making up for a standard horn or by figuring out a lip that provides smoothing the same way as rectangular OB provides smoothing over a circular OB.
Michael
Hi Michael,
Have you sketched out any HORN LIPs which use the contours you have been working on? 90 x 40 constant directivity horns are popular for 1" compression drivers since they mate well with 10" midbass cone speakers.
Old 26th January 2010, 05:20 PM   #29
mige0's Avatar
I possibly will - once I do a more refined version - but don't hold your breath on that as I might go into other variants first - anyway, its nice balanced in effort versus outcome as it is right now, IMO
Michael
Old 21st February 2010, 01:47 AM   #30
Inductor is offline Inductor  Portugal
Inductor's Avatar
Nice. (Here) The "bunker" version on steroids.
Floating Opera House for Toronto
Link: Funk music old school
Beautiful Swingin' SpeakerHide this!Advertise here!
Thread Tools
beautiful and good sound speaker weimanken Multi-Way 9 27th October 2008 05:36 PM
Most Impressive, Beautiful Veneer for speaker baffles thadman Multi-Way 7 16th August 2007 12:44 AM
Beautiful tubes. andrew_whitham Tubes / Valves 59 21st March 2007 02:23 PM
my GC is beautiful! glyphin Chip Amps 4 15th July 2003 04:26 PM
America The Beautiful..... Negative Design The Lounge 4 27th May 2003 05:00 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
