Instruments and Amps Everything that makes music, Especially including instrument amps.
Why loading a guitar pickup loose high frequencies
Thread Tools
Old 16th October 2021, 12:29 AM   #11
steveu is offline steveu  United States
Guitar pickups have massive inductance but others including the Rhodes piano are worse with many coils in series. The inductance is so high that the impedance of the guitar cable produces a noticeable effect. This is why Les Paul made Low-Z instruments.
GIBSON Les Paul: Low-Impedance Series electric guitars
Unused inputs should short themselves and loading a pickup is not going to improve the s/n. This is an advantage of valve amplifiers that is rarely discussed, but can be achieved in solid state amps if the issue is well understood. A input bootstrap circuit produces a hi-Z input and may add some 2nd order harmonics.
Old 16th October 2021, 01:23 AM   #12
bucks bunny is offline bucks bunny  Germany
Burns/UK built some low impedance guitars as well
Old 16th October 2021, 07:30 PM   #13
gab far is offline gab far
Hi Steveu, you say "loading a pickup is not going to improve the s/n." I'm not sure about this. If you model the pickup as an inductor and resistor in series, it has limited ability to shunt induced EMF noise voltage from the environment to ground, because of its inductance. Seems to me an added shunt resistor can help to ground out some noise, especially at high frequencies.
Old 20th October 2021, 12:28 AM   #14
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by egellings View Post
Buffer the pickup at the guitar, if possible.
This is the best approach.
However just buffering the high Z guitar pickup in guitar is no ticket to great sound. Every single high Z pickup want's to see a C + R loading to finely tune
it's response and feel. There is a sweet spot or to be more accurate, many sweet spots and conversely many loadings that don't sound particularly good.
For example you can get a very high OP humbucker to sound very bright but it will definitely not sound very good.
TCD
Old 20th October 2021, 01:31 AM   #15
Yes, especially the capactor connected to the tone knob on the guitar. It forms a resonant circuit with the inductance of the pickup, and when the tone control pot is turned to a low resistance can give a pretty distinct voicing.
Old 13th November 2021, 09:41 AM   #16
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by steveu View Post
...Les Paul made Low-Z instruments.
The interesting thing is that no other guitarist went on to emulate Les Paul, and neither did any guitar pickup manufacturer.
They've had many decades in which to do so if they wanted to. The obvious conclusion is that nobody wants to.
Listening to old Les Paul recordings and videos on You TUbe, to my ears, the guitar tone that Les Paul got with his low-Z pickups is quite unpleasant. Thin, cold, steely, and very unattractive.
I suspect that most other guitarists who came after Les Paul (his actual name was Lester Polsfuss) feel the same way I do. Which is why nobody else found low-Z pickups with extended treble response pleasant. Polsfuss was the last guitarist who thought they were a good idea.
(IMO Les Paul's tone was awful, but his playing, on the other hand was fantastic. He was a heck of a guitarist. Even though he constantly lied about being the inventor of the electric guitar. That was actually George Beauchamp, who was selling his Rickenbacker A-22 "Frying pan" electric guitars in 1931, while Polfuss only put together his "Log" some eight years later, around 1939.)
There are actually still low-Z magnetic guitar pickups manufactured today, but they are specialty items used only on electro-acoustic guitars (like some of Taylor's offerings), or on solid-body guitars trying to sound like acoustic guitars (like the Shadow Nanomag pickup installed as a third pickup on some Epiphone Les Paul Ultra models). Their purpose is to sound more like an acoustic guitar than an electric guitar.
I once did some experiments with a guitar, an extended-response piezo pickup, and a graphic equalizer. I used the EQ to filter out all frequencies below 5 kHz or so, so I could listen to just the remaining high-frequency output.
I found that what remained sounded harsh, scratchy, ear-fatiguing, and unmusical / out of tune. At least to my ears, the output of a guitar above 5 or 6 kHz is not musically attractive at all. This applies to both electric and acoustic guitars.
The "out of tune" part, by the way, is predicted by the mathematics of vibrating-string theory; because actual guitar strings have stiffness (they are not mathematically ideal perfectly flexible strings), their output is not a pure harmonic series - higher frequency overtones are increasingly "out of tune" and more dissonant with the lower-frequency tones.
Somewhat shockingly, the electric guitar is ninety years old this year. Like most century-old inventions, it has been nearly perfected along the way. There's always room for new ideas, but guitar pickups and amps have limited frequency response for a very good reason - they sound better that way.
These days, many guitarists play through a digitally modelled guitar amp and an digitally modelled speaker/cab simulator. It would be trivially easy to make a cab sim with a wide frequency response out to, say 20 kHz, if you wanted to.
But nobody does that, because the results sound horrible, like being stabbed in the ears with needles.
-Gnobuddy
  Reply to this post
Why loading a guitar pickup loose high frequenciesHide this!Advertise here!
Thread Tools
Why do SMPS sound rolled off in the high frequencies? stretchneck Power Supplies 8 5th May 2020 12:13 PM
Why are the crossover frequencies so high? joe Car Audio 4 20th April 2019 10:27 PM
Add magnetic pickup to piezo pickup and preamp. sranauta Instruments and Amps 0 31st December 2014 12:31 AM
Anode Loading Vs. Cathode Loading ? valveitude Tubes / Valves 19 22nd July 2005 11:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
