Instruments and Amps Everything that makes music, Especially including instrument amps.
Blackstar combo 20 that squeals
Old 21st October 2014, 04:09 PM   #11
turk 182 is offline turk 182  Canada
any effects patched in inline or on the loop or is this just the amp with your guitar(which is what a Strat or...) and have you tried another signal source as in low level audio?
you should try Enzo's suggestion about the tubes.
also is this happening on both the clean and dirty channels?
Old 21st October 2014, 04:15 PM   #12
brewback is offline brewback  United States
No effects- Just a Fender/Gretch slid guitar and a Tele with Di Marizio "Twang Thang". Same problem. Tubes where swapped with new and biased. Low level audio, I havn't tried......thanks
Old 22nd October 2014, 02:30 PM   #13
Jarno is offline Jarno
To repeat my previous question, does it have a SMPS B+ supply or a linear B+ supply?
Oemptempa petoempetapap
Old 22nd October 2014, 06:14 PM   #14
Sorry- I'm not that knowledgeable. I'm somewhat of a beginner/intermediate.
How do I tell?
Old 22nd October 2014, 09:12 PM   #15
Did you open it up already? (mains lead unplugged, and left for a while to make sure capacitors are drained)
If so, could you post some pictures of the insides and particularly the main PCB?
Some of the newer guitar/ bass amplifiers have SMPS PSU's for the B+ voltage as these are more compact (lighter!) than conventional PSU's. There's a big Fender bass amp which has this, and probably a few others. And I believe some/ all of the blackstar amps have SMPS PSU's.
These work by (attention: extremely non-engineeringlike description) creating a alternating current, with a much higher frequency than regular mains voltage (50Hz, 60Hz). The reason for this is that transformers can be made a lot more compact and work better for these higher frequencies. The drawback is that these high frequencies can find their way to the audio path, which leads to a whining noise. Careful layout, grounds in particular, and proper filtering can keep this from happening. But if there's a not so nice ground somewhere, or caps going bad, this can cause trouble.
Blackstar combo 20 that squealsHide this!Advertise here!
Which combo XP-30/XA100.5 or XP-20/XA160.5 LTo Pass Labs 3 5th June 2013 11:32 PM
Blackstar Amps mains connection? eem2am Instruments and Amps 1 14th July 2012 11:18 PM
Maximum power of Blackstar ID series? eem2am Instruments and Amps 19 21st June 2012 08:05 PM
where can i buy a replacement PSU for my Blackstar pedal? mondogenerator Instruments and Amps 6 24th December 2010 02:41 AM
No output and Loud squeals! Help! skid20 Tubes / Valves 5 2nd May 2010 05:07 AM
Copyright ©1999-2019 diyAudio
