back to basics, again
I don't know where you buy stuff in US
but I would only buy a good known and proven brand for musical instrument
there might be other options and ways to do it
but without any experience you better stick to the known stuff
how about this Orange 'thing'
http://www.orangeamps.com/products/bass-guitar-amp-combos/crush-pix-series/crush-pix-cr100bxt/
Lugging it
Welcome to the joys of playing bass!
There's many ways to skin this cat - the key question is whether your speaker is part of your "instrument" (ie. fundamentally part of "your sound") or not.
If it is, then you're stuck with lugging that kit and miking it into the house PA. You should be able to add extra cabinets for big stages.
If not, then you can DI into the house PA and you've got the freedom to add/subtract amps and "PA" speakers as needed - lugging only a small speaker 90% of the time.
I was from the latter school and my stage set up was a 12" foldback wedge at stage front (next to the PA wedges) plus a 2 x12" sealed box (with tweeters) at the back pointing diagonally across stage at the singer, guitarist(s) & most importantly, the drummer.
.... but carrying 200lbs+ of stuff around isn't very fun
Would a plate amp be what I'm looking for here??
not at your low budget
I suggest you take a look at TC
the latest advanced technology is not expencive
toneprint means you can download effects
http://www.tcelectronic.com/bg250-family/
Faking it.
I've not seen any PC or i-thingie based stuff I like. And having either in your stage chain is not good.
I have a soft spot for the Vox Amplug (esp the bass one). One of those will drive any PA (or home stereo) based set up nicely.
And, for guitar, the Vox valvetronix and yamaha/fender equivalents are rather nice. Cheap at pawn shops too - not sure if there's a bass-amp equivalent.
..the amp reproducer type things ...do they come close?
- Live Sound
- Instruments and Amps
- Bass guitar to Passive PA Sub?
