Headphone Systems Everything to do with Headphones
How to create a headphone connection
Thread Tools
Old 5th June 2021, 03:44 AM   #1
rtcary is offline rtcary  United States
Default How to create a headphone connection
I have an Apple TV 4 connected to my Sony amplifier. The Sony has no mic jack or other outputs. Is there a way to get a way to have an access to the output other than converting the stereo speaker outputs via a converter to audio out standards?
Any suggestions are appreciations.
Todd
Old 5th June 2021, 05:56 AM   #2
sofaspud is offline sofaspud  United States
sofaspud's Avatar
The only external method I can think of is using the Tape Out jacks, if your amp is equipped for that. It's a fixed-level signal so you need a volume control separate from the amp's front panel control.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 5th June 2021, 03:31 PM   #3
Unfortunately there is no output(s) what so ever - I assume this is part of the HDMI/copyright regulations.
\rtc
Old 7th June 2021, 07:22 AM   #4
enregistree is offline enregistree  Europe
enregistree's Avatar
HDMI audio extractor put between atv and amp, and any spdif input headphone amp.
Small box, with toslink (and coax) digital audio output. Kind of hijacking audio from atv, with keeping hdmi connection to amp.
Old 12th June 2021, 11:43 PM   #5
dangus is offline dangus  Canada
How about the monitor or TV? Even computer monitors with HDMI inputs usually have an audio jack, sometimes an optical output. I found that I have to use a passive attenuator with my Samsung monitor because the output level is too high (and neither the monitor nor my media player have volume control).
  Reply to this post
How to create a headphone connectionHide this!Advertise here!
Thread Tools
TDA1557q amplifier 4pin to headphone connection mariano747 Headphone Systems 1 16th November 2018 05:20 PM
Headphone connection to preamp or amp... Manolo47 Pass Labs 1 10th March 2012 08:04 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
how to create a synth or dj Equipment abraham Everything Else 1 22nd May 2001 01:31 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
