It's certainly doable if you want to.
The filaments need a total of 3.6ADC. The HV supply needs about 280mADC at 370VDC.
Notice that the original circuit floats the filament supply at +13.5VDC.
Have you considered changing to separate, fixed bias operation?
You'd need a new negative bias supply for that.
The standard circuit uses (and needs) a matched quad for the outputs.
At the least, it would be easy to convert to two matched pairs of output tubes,
instead of a matched quad, by using a separate cathode bias resistor/capacitor per channel.
Would like to us Mercury Magnetics DYNA-PA60-P transformer. I have an adjustable bias circuit in the amp. 6.5V filament with center tap is what is supplied with the OEM Transformer and HV is 330v with center tap 660 rail to rail. I want to split filament supplies one left one right DC and over kill on filtering.
Scott Pike
Scott Pike
This low drop out adjustable voltage regulator should be good for the two 1.8ADC filament regulators.
Use a full wave 35A bridge rectifier, with a capacitor input filter, on each of the two 6.3VAC secondaries.
See page 5/17 here:
Data sheet: https://www.st.com/resource/en/datasheet/ld29300.pdf
Digikey: Blocked
See page 5/17 here:
Digikey: Blocked
Very nice amplifier.
You intend to remove the power transformer/rectifier/input capacitor from the chassis?
- Headphone Systems
- Dynaco power supply ST35
