Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Group Buys Members group buys |
As suggested in my thread about my high voltage regulator for tube amps, this is the Group Buy thread for it.
I am offering the following half-kit: - PCB; - Current source LT3092 SMD soldered to the board; - overload reset switch SMD soldered to the board; - Pass device FDP12N60NZ; - low current high brightness LED; - depletion mode HV MOSFET IXTP08N100D2. Everything else is easy to find and/or already in your parts box. Asking € 30 plus shipping at cost (most destinations € 6). All info for building can be found here: T-reg HV regulator | Linear Audio NL Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit Last edited by jan.didden; 21st October 2019 at 04:41 PM. |
#2 |
euro21 2pcs
#3 |
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit |
#4 |
How about a negative version ?
![]() Patrick
xen-audio.com |
#5 |
#6 |
For example.
![]() Patrick
xen-audio.com |
#7 |
Working on it ...
Edit: OK done ![]() Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit Last edited by jan.didden; 19th October 2019 at 04:56 PM. |
#8 |
Bela please send me your address and phone # with PM.
Jan
#9 |
I thought you already had it working ??
![]() Patrick
xen-audio.com |
#10 |
Yes. Not pub ready, but close. +/-400V adjustable, separate adjustable bias, plus as bonus 2x6V for any opamps in the amp.
Uses a specific Antek xformer, hence the PCB size, which sits on top of the Antek I wonder whether it would need a current limiter? Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit Last edited by jan.didden; 19th October 2019 at 05:18 PM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Maida-Style High Voltage Regulator PCB Group Buy | SpreadSpectrum | Group Buys | 2 | 9th July 2015 02:25 AM |
T-reg-high voltage regulator | misterno | Elektor | 2 | 15th March 2015 06:25 PM |
High Voltage Regulator | mod_evil | Power Supplies | 36 | 28th October 2011 01:48 PM |
high voltage regulator | wleediy | Solid State | 2 | 4th August 2009 08:12 AM |
High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 10:43 AM |
New To Site? | Need Help? |
