the second and later visual front panel is also cut out on a CNC. Here we have placed the Monacor SPH 135-KEP
http://www.monacor.com/de/produktseite_gesamtprogramm.php?artid=2078&spr=DE&typ=u
each SPH-135KEP is playing into a 13-14 ltr BR-volume.
the Fe127e is playing in closed 2,7 ltrs.
To get the surface smooth I had to sand every box for about 8-9 hours (with profesional tools ). But I enjoyed every hour now to see how nice it looks and also sounds. The first pair (that I have build) is in my bedroom.
I have tried a similar project with the Fe127. But the Fe127 only needs 0.8-1.1 ltr.
edjosh23 said:Very nice,
How do they sound?
Josh
Hi Josh
I like the sound and I can only recommend to try the Fe127e in about 2,7 ltr if you want/will add a bass under the fullrange driver.
regards Till
Hi Till,
really like your designs. What makes me wonder: The fe127e does not simulate very well in enclosures that small. The frequency response gets a little bump at ca. 230 Hz ( which does not matter) and the transient response gets very slow in the simulation. I know that the TS from Fostex are not that exact - especially for a well broken in driver but I'm still wondering if the fe127e in that configuration could cope with the speed of the bass units I'm planning to use with those little drivers (Eton 8-480/32HEX). In larger volumes the transient respones looks very much better.
Are there any issues withe the speed of the Fostexes in that boxes?
regards
Flo
regards
Flo
- Full Range
- working with the Fe127e
