OB FAST with 3.5in Fullrange and SB23NRXS45-8
Founder of XSA-Labs
Joined 2012
This thread is a spin-off from the 10F/8424 / RS225-8 FAST speaker thread here:
https://www.diyaudio.com/forums/ful...rs225-8-fast-waw-ref-monitor-post5893670.html
777017d1566577438-10f-8424-rs225-8-fast-waw-ref-monitor-sb23-ps95-fast-03-jpg
I had some extra baffles made up when I had the 10F/RS225 cabinets made. I had bought the SB23NRXS45-8's a long time ago, meaning to try them in the sealed box FAST with a 3.5in fullrange in a separate Dagger chamber. The RS225 setup with the 10F sounds so good, I never got around to trying the other woofer. Until today that is. I decided to just put it all together and listen it in the open as an OB to save time since I did not want to remove the baffle from the other speaker. Using the same passive 1st order transient perfect XO, I connected it all up. Added some aluminum MakerBeam supports held together with 3M Bluetape and plugged it into my amp and had a listen. Not expecting much, but instead - I was blown away by the sound quality. The dynamics, clarity and ease of presentation. The bass was less than a sealed speaker of course, but it wasn't bad. A subwoofer would handle the transition very nicely. This is a very narrow 10in wide baffle. Something a little bigger or even something with some fold back wings would improve bass a lot.
It sounded so good, I knew it was special and deserves its own thread as an OB. Although I am using a PS95-8 for the fullrange, any 8ohm 2.5in to 3.5in fullrange would work here: TC9FD, TG9FD, 10F/8424, B80, 3FE25, 3FE22, FF85WK, P839086, etc. I happen to be listening to it first with the PS95-8 and the sound is wonderful.
I think a lot of the quality comes from a good smooth shallow first order XO that allows a broad range of the wonderful SB23's qualities to come through. The SB23 is a papercone woofer vs the RS225's aluminum cone. They have a different sound. Both are great - but different.
I just wanted to bring attention to the fact that this speaker (or even the 10F/8424 and RS225) and its progenitor, can simply be stripped of the rear chamber and made into a compact OB. In some situations like an aprtment with close by neighbors, you may actually want less powerful bass. But the rest of the music can still sound superb.
777016d1566577438-10f-8424-rs225-8-fast-waw-ref-monitor-sb23-ps95-fast-02-jpg
777015d1566577438-10f-8424-rs225-8-fast-waw-ref-monitor-sb23-ps95-fast-01-jpg
XO being used is same as one for 10F/RS225:
656203d1515700364-10f-8424-rs225-8-fast-ref-monitor-xrk971-10f-rs225-fast-schematic-jpg
I added a second channel for stereo sound:
attachment.php
Then I measured the response with a calibrated UMIK-1 and REW. As expected, there is a 6dB/octave falloff of the bass starting at around 600Hz:
attachment.php
Using the REW EQ utility, I found that using a combination of a -6dB peak filter with Q=0.6 at 700Hz and a low shelf of +6dB at 250Hz gently flattened the response:
attachment.php
Applying these two simple parametric EQ's in Jriver's DSP utility, the sound is now very good. Here is a recording of some classical guitar in the attached mp3 file. Change the extension from .asc to .mp3 to listen.
I know there is a way to get Jriver to run a sound processor in the background even when you are using another program, but I don't know how to do that just yet. Once I figure that out, I can take another sweep with the DSP EQ in place.
  • SB23-PS95-Test-2.asc
I just got some tips from Byrtt on how to use Jriver DSP as a pass through for all audio apps. I want to take another sweep with the EQ applied to see what it looks like. Tricky stuff though with the sample rates etc being different.
I could also try out my new DSP from AD - ADAU1452 eval board. It lets you do wire diagram filters with point and click - SigmaDSP Studio.
F3 at about 40Hz. Quite decent.
The SBA woofers can handle extra low end EQ no problem, with negligible distortion.
Also, try spacing them a bit farther apart, and toe them in. Spatial cues should be improved.
How far are they from the wall behind them?
I had a quick look at that board. About $250. How does it compare to something like miniDSP 2x4 HD?
3.5ft from wall and I did toe them in. Imaging is very nice.
I am using the ADAU eval board to make a custom DSP. It has 8 channels out and the programming is very powerful - can do a lot of stuff like FIR etc and only limited by on board memory space. A custom designed one can be less expensive than eval unit of course and use the nicer DACs etc.
