I have been kicking around the idea of building a compact enclosure (front-back loaded I haven't decided) for the Dayton ND65-4. The speaker has an fs of around 90 HZ. My question is how do determine what to use for the lower and higher cutoff frequencies. I understand the formulas, the question is do you set the lower cutoff frequency at fs, higher or lower.
Have a look at the Frugel-Horn Lite.
Compact & Horn do not usually belong in the same sentence. Most small boxes called horns are actually badly designed TLs.
dave
dave
