Chill-Baffle2 speaker (L-baffle, full-range + woofer)
In the meantime, I extended the Chill Baffle 2 with an ESS AMT tweeter:
I chopped off the top part of the baffle and glued this on top so I could mount the AMT. The added AMT driver greatly increased the speed, detail level and cleanness of highs, great stuff! 😛
My current configuration is:
- 18mm MDF open Baffle with assymetric wings.
- Pure Audio Project 15" woofer (used till ~200 Hz).
- Supravox 8" Signature Bicone (used as mid from ~200-1200 Hz).
- ESS big (Heil) AMT (from ~1200 Hz).
- 3x20 uF cap and 2.2 ohm resistor in series with AMT (capacitors parallel naturally).
- Fusion 253 plate amp with reduced gain for better SNR and lower idle noise.
- JL sounds USB to I2S with Ultrabib v1.3 5V supply, SPDIF output to Fusion.
- PC with Winamp, custom output plugin & EQ software.
I use Harsch XO for both crossovers. This reduces phase shift considerably compared to Linkwith-Riley crossovers. I really like the improvement it brings (a more live and engaging sound IMHO).
I am quite happy with achieved sound in this setup... :cheerful:
Still, I am already working on its successor with improved baffle and drivers... more to follow soon...
Hi, I'm interested in this "L-frame" idea, in fact I started a thread recently asking about the polar response. I haven't seen any measurements as yet, would you have any or be able to do some? What improvements are you planning for the baffle?
I want to move to a sort of bottle shaped baffle, rounded and less wide on top for mid driver and AMT. Also I want use better quality MDF or MPX and thicker: 2x18mm. Also I want to mount the drivers closer to each other. Hopefully this will make it easier to measure them... (and improve the stereo imaging further)...
I simulated the Chill Baffle2 with Boxsim, by unfolding the Wings (and thus extending the baffle). Probably not fully accurate. The new design I only simulated in Edge yet, front baffle only. I only want to add wings to woofer this time. Maybe a minor ridge for the mid as well if measurements are not flat enough...
