hello
exusme i am not good at english
i not can folow a brand full range or woofer
but i folow this 8" full range
بلندگو 8 اینچ | الکترونیک فراز
http://faraz-shop.com/wp-content/uploads/2016/12/FM-200-2-300x300.jpg
http://faraz-shop.com/wp-content/uploads/2016/12/FM-200-7-100x100.jpg
http://faraz-shop.com/wp-content/uploads/2016/12/FM-200-3-100x100.jpg
this is good woofer?
Yes, and without that information, it would be impossible to suggest a design for you.
Speakers are not like tyres for cars. We don't know if they fit just by looking at the size.
Please provide the maker's name and model number which cannot be read in the photos.
Note that most drivers this size will "beam" at higher frequencies and may seem "forward" in presentation of vocal recordings, strings and percussion.
انگلیسی شما کامل است، هیچ تجدیدنظر لازم نیست.
woofer mark : empirePlease provide the maker's name and model number which cannot be read in the photos.
model : fm-200
nom : 80w
max : 100w
inmpdance : 8 ohm
made in china
This is a copy of things you need to know before designing a box for it.
As you can see, you need more than just Watts and Ohms...
It's a chinese woofer without any available information on the brand and typename.
The rest of the speakers sold in that shop is chinese low budget stuff.
I think it's safe to say it's not a good woofer.
i knowIt's a chinese woofer without any available information on the brand and typename.
but i not folow a good speaker
can you help me for folow a good speaker in iran??
When I do a Google search for HIFI speaker components available in Iran, it only lists one seller of mobile [car, truck, etc.] audio drivers, none for HIFI, so unless you or someone else can find one and has at least basic T/S specs [Fs, Vas, Qts] listed we cannot help you.
If you choose to buy car audio drivers, then either mount them on large open baffles [old doors, large table tops, etc.] or largest sealed box you have space for and add stuffing as required to make it sound as good as you can and hope it sounds 'good enough'.
Otherwise, you or someone else will need to measure the T/S specs of whatever drivers you buy. Many sites to choose from to explain [use Google to translate]: measuring t/s specs - Google Search
GM
GM
ok tanks for youWhen I do a Google search for HIFI speaker components available in Iran, it only lists one seller of mobile [car, truck, etc.] audio drivers, none for HIFI, so unless you or someone else can find one and has at least basic T/S specs [Fs, Vas, Qts] listed we cannot help you.
GM
- Full Range
- help for make a full range box
