Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#21 | |
I agree.. I'm just trying to figure out what would be the best speaker arrangement I can do for the size of the unit i'm dealing with. -And 4 speakers are the maximum. ...At first, I made a box with (2) 3-1/2" full range drivers and (2) 1" dome tweeters. I can get a decent sound out of it, but i'd like to re-do the unit to sound a little fuller on the bottom. |
#22 | |
When you say, "Your 'full range' drivers will take less bass", do you mean that they will actually play less bass? If I have the system wired in a way that splits the audio signal two ways: 1- Amp pushing two FR drivers 2- Mono-amp pushing sub Then, if the low-pass crossover is placed before the sub, it will still affect the sounds coming out of the FR drivers that were split to another amp? I thought that for the FR drivers to be affected, they would also need to be connected to a crossover, maybe a 2-type... |
#23 |
He meant that the crossover for BOTH the full range and the sub should be a little higher. That means the sub plays up to 180Hz then starts to fade, and the FR play down to 180Hz, then start to fade.
Not asking a smaller driver to play those lower frequencies usually frees it up and makes it sound cleaner in the higher frequencies. Look at this graph, just move the XO at 180Hz, and picture that the woofer is the sub, and the tweeter the FR.
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
The components for the sub are not the same as the ones for the FR, if you are doing it passive. An easy way to deal with XOs is to make them active, so no added components, using a miniDSP module. Using that module, you can move around the XO with just a few clicks of the mouse. Quite convenient. https://www.minidsp.com/products/min...ox/minidsp-2x4 |
#24 |
Hmm, different strokes........after looking at the responses and the bulbous surround on the 4", I'd try 500-600 Hz/1st order to start with and maybe work down from there.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#25 |
#26 |
^ Yes, you are right, a crossover is two or more filters, in this case a high pass and a low pass that combine to "crossover" the frequencies to the drivers
#27 |
.....with the understanding that the low pass can be just the driver's HF acoustic rolloff.
GM
#28 |
Even though the FR driver will have falling LF acoustic output below its natural corner, or depending on the enclosure, a higher frequency, I doubt it ever hurts to high pass filter it to avoid overtaxing the drive train .
It’s been a slice kids |
#29 | |
And the resistor summing network in Post 3 was also very informative and useful. I learn more every day. Thank you. |
#30 |
An alternative to using a summing network would be to use one of the twin coil Monacor drivers (eg 135 TC) Each channel connects to it's own coil on the same driver. Not necessarily better, but an option.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
FS in Los Angeles, beefy subwoofer setup, H-frames, full-range drivers | taloyd | Swap Meet | 16 | 7th August 2013 05:13 PM |
Why not full range with a subwoofer? | Ultralight | Full Range | 38 | 14th June 2011 11:18 PM |
Full Range driver - 5.1 setup possible? | penguinpoo | Full Range | 24 | 1st March 2011 09:58 PM |
full range ht setup help | kazoo | Full Range | 18 | 17th November 2007 04:19 AM |
Advice on full range enclosure for 5.1 setup | CDJ | Multi-Way | 3 | 21st January 2003 06:28 AM |
New To Site? | Need Help? |
