open backed Tapered TL? reverse-taper-into-BIB? zero-net-taper-1/2 wave resonator?
Old 11th March 2010, 02:22 AM   #1
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default open backed Tapered TL? reverse-taper-into-BIB? zero-net-taper-1/2 wave resonator?
imagine a tapered TL, folded once, but designed as a non folded line.
basically like a one fold design built within a rectangular box, with a centre partition that forms the fold, EXCEPT that back is left off the enclosure.
the line area at the bend in the line is equal to the desired vent area, and the first half of the line is calculated, with taper, to be the desired total line length.
the 2nd half of the line would expand with the inverse ratio to the first.
Along the lines of this:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
or maybe even something a little more like this look wise:
if anyone out there understands me, would anyone like to hazard a guess as to the effect of doing this? or could hornresp model it ?
No really, those CC resistors aren't worth using for kindling, let alone electronics
Old 11th March 2010, 02:49 AM   #2
GM is offline GM  United States
GM's Avatar
Been there, done that a number of times and yes, it can be modeled in Hornresp. It's just a freestanding version of the simple little Klipsch/Jensen/EV BLHs of the '50s.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th March 2010, 02:52 AM   #3
GM
lol ok. i was only JUST around in the 70s so excuse my naivety
Old 11th March 2010, 03:33 AM   #4
GM's Avatar
Wasn't making light of your idea, just there's not really anything new in driver alignments, just variations on a theme with 'breakthroughs' due to advancing materials, manufacturing technology and increasingly powerful digital signal processing.
Anyway, these are a lot of fun, especially the corner loaded variants. I built a single freestanding one 6-7 yrs ago for a mono setup loaded with a 6.5"/~65 Hz Fs 'FR' RadioShack driver and the few folks that auditioned it were stunned at its 'slam' and extended LF. A properly done Karlson would probably have a little more 'slam', but wouldn't have as much extended LF as the trade-off. Not many 'free lunches' in audio.
GM
Old 11th March 2010, 03:47 AM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
GM
I dont know that Klipsch
But fore corner load, or using backwall, maybe turn it the other way round
sometimes we know very little, and sometimes we know too much
Old 11th March 2010, 04:34 AM   #6
@ GM : NO offence taken. i didnt think i had invented anything, i was just asking about what the effects on response would likely be, given that the first part of the line is optimised for TQW alignment, as is the vent area.
lol it looks like a nice experiment, i should try and download hornresp and give it a try, assuming i can get my head around the program.......
@ tinitus: excuse me if im clutching at straws here, but isnt what you propose in your drawing a voigt pipe?
Last edited by mondogenerator; 11th March 2010 at 04:36 AM. Reason: voigt...voight? maybe i should look his name up and make sure i spell it right, poor fellow.
Old 11th March 2010, 04:56 AM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I have a recent sketch from Scott, a BVR for the FE126, that has a striking similarily to m'd'g's sketch.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 11th March 2010, 05:15 AM   #8
Default really???
wow well thats about as big a compliment as im ever going to get on here!!!
um...
if only i could find an idiots guide to using hornresp.......as ive had a play with it and the SPL response doesnt look too clever.... big 10dB peaks etc....
area 1 = 290 area 2= 20-30 and area 3 = about 1000-1500 L1 = about 100 thus L2(if applicable...im a bit lost here) = about 100 also.
looks a rather rough though.....
Old 11th March 2010, 07:10 AM   #9
freddi is offline freddi  United States
freddi's Avatar
lilmike's guide tp hornresp looks good
Simple Tapped Horn Tutorial using Hornresp - AVS Forum
Old 11th March 2010, 02:05 PM   #10
GM's Avatar
Ah, OK. Well, because the line is much more efficiently loaded it will have a wider gain BW and due to having a too 'fast' a flare (too large a mouth for its length) it will have a much higher Q (stronger) HF 'ripple' BW that causes much of the 'slam' part of its gain BW.
For it to 'be all it can be' the line side must be optimized for efficiently loading the secondary horn, so the TQWT part is optimized for the LF and the 'fast' horn for its HF BW. Fortunately, one no longer needs to be conversant in TL/horn theory to do it now that DB has expanded his 'slider' horn Wizard to include such esoterica, though of course knowing it will shorten time spent simming.
Don't forget to combine the driver/port responses, HR doesn't automatically do it as other programs do.
Note too that HR apparently assumes ~infinitely rigid boundaries/whatever as its peaks/nulls are much higher in amplitude than measured plus once you damp the system to 'taste' and combined with the room's response they don't sound anything like the sim except in the most general of terms, so when looking at it, draw an averaged mental line through all the peaky 'hash' to get an idea of its outdoor half space response, i.e. keep the hash' high Q with no deep, wide BW nulls since we tend to key on just the peaks otherwise.
GM
open backed Tapered TL? reverse-taper-into-BIB? zero-net-taper-1/2 wave resonator?Hide this!Advertise here!
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 05:05 PM
Open backed boxes ? Anyone ? norman bates Full Range 37 6th September 2008 02:19 AM
Do TL lines need to be smoothly tapered? GuyPanico Subwoofers 5 16th April 2005 08:01 PM
Calculating bends in a tapered TL bwbass Multi-Way 12 5th February 2005 08:58 PM
TL tapered design help/comments sunil Multi-Way 10 14th September 2004 02:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
