Basrefleks should make it straight to 50hz
120-140 liter netto, with BIG slotport 100x400mm x100
I tried calculate with 275 liter and just a 100x400mm slot opening, not a port...pushes it down to 35hz
Have been used a lot in PA
Could be its a woofer well suited fore ONKEN, I dont know...but its suggested on Supravox site...dont know if its the optimum
You don't specify exactly what sort of cabinet you're after, and 'best' is at, er, 'best' a subjective term, so we're going to have to wing it here.
Something like this MLTL ought to get you started:
42in long, CSA 221in^2, Zd = 17.625in, Zp = 38in , vent 4in diameter x 1in long.
- Full Range
- SUPRAVOX 285 GMF cabinet size
