Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Zip cord for speaker test
Thread Tools
Old 10th June 2021, 10:34 AM   #231
Hans Polak is offline Hans Polak  Netherlands
Originally Posted by danny_66 View Post
Hi Hans,
how do you calculate the values of the LCR ?
Hi Danny,
In short:
To start with, measure with a VNA the open and shorted impedance of the cable.
This gave me resp the inductance and the capacitance of the 2.5meter 4mm^2 cable, resp 1.5 uF and 150pF. With sqrt(L/C) this confirms Zo=100R.
Now to get Zo=4R such as in my case, from 4=sqrt(1.5uHu/C) it can be calculated that C must be 93nF, so divided over 3caps gives 31nF per cap.
When simulating Zo in LTSpice, you will find that you still need a resistor and a coil in series with the cap, of resp 600nH and 9R, but taking into account the 150nH and 1R that the cap has, I needed resp. 450nH and 8R.
Be aware that these inserted LRC components better be able to withstand a few Amps to prevent added distortion.
Hans
Old 10th June 2021, 10:38 AM   #232
Originally Posted by peufeu View Post
Does anyone know what's inside the mystery boxes on this MIT cable?
Sorry, I forgot the image.
Here it is.
Hans
File Type: jpeg DC23B925-74B3-45AC-96FE-00B1A6A47811.jpeg (138.4 KB, 126 views)
Old 10th June 2021, 10:52 AM   #233
Originally Posted by planet IX View Post
I would gladly repeat this experiment, but my speaker cables need to be a bit longer.
So should I repeat the network any 0,625 meters?
What cables do you have and how long are they ?
Hans
Old 10th June 2021, 11:09 AM   #234
planet IX is offline planet IX  Germany
planet IX's Avatar
At present I use a solid-core cable 2*1mm˛ (originally Siemens Profibus, I think)
I guess its 3-3,5m long, I can check it this afternoon.
I could also measure the impedance,as you described above.
I had MIT cables in the 90s, also some other not so cheap cables (Kimber, van den Hull). But then I once tried solid core cable (there are hunderts of meters in the Opt of my Tubeamp, was my thinking, so it coulnd't be that bad) and ever since then I use solid core loudspeaker cables. But I'm always open for new expereiences...
Old 10th June 2021, 11:23 AM   #235
Ok, when I know the inductance and the series resistance, I can do the calculation for you.
Hans
Old 10th June 2021, 12:30 PM   #236
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Thanks for the guide.
A VNA is missing in my toolbox,
there are some cheap VNAs on ebay/banggood/Ali, what are the specs I should be looking for in a VNA ?
My RefSpeaker v2
Old 10th June 2021, 01:02 PM   #237
Can you give me a link to such Alibaba device.
I’ll have a look at it and give my comment.
But you can also do a inductance measurement with the cable shorted at the other side.
And in the same way you can measure the DC resistance.
Those two parameters are the most important.
Hans
Old 10th June 2021, 01:12 PM   #238
1audio is online now 1audio  United States
Look for Nanovna. They have a web site with lots of details. NanoVNA | Very tiny handheld Vector Network Analyzer Many variations out there. Watch for clones. All less than $100.
Demian Martin
Product Design Services
Old 10th June 2021, 01:15 PM   #239
danny_66's Avatar
Here are some on banggood for about 50€
My RefSpeaker v2
Old 10th June 2021, 04:49 PM   #240
Evenharmonics is offline Evenharmonics  United States
It amazes me that DIYers on this forum are spending large sums on all sorts of nice project in search of the holy sound grail, but when the option is there to possibly improve sound with very low cost manipulated LS cables, there is no animo.
And believe me, blind listening tests are not needed to hear the difference, it is so obvious, at least in my case.
Although no satisfactory physical explanations exists and although
Of course cables can make audible difference if they are bad enough.
many people are prejudiced that cables cannot make a difference,
Where are those many people?
wouldn’t it be a challenge to give it a try and leave your comfortzone for once.
All you need are 6 resistors, 6 coils and 6 caps plus 2*2.5 meters 4mm^2 zip cord.
Hans
Why should they try the cable equalizer when there are real equalizers out there.
Zip cord for speaker testHide this!Advertise here!
Thread Tools
FS: power cord MIT Z-cord indaco Swap Meet 0 6th September 2020 05:27 PM
Dual coax zip cord style cable percy Parts 2 13th May 2014 05:40 PM
Don't zip PDF files jwb Everything Else 1 23rd March 2003 05:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
