Guys, does anyone thinks running a tv backlight less that the supply ratings on current or voltage?
How does one limit the current on the Chinese design (universal TV boards) or slight mod (fixed or trimpot) to adjust the volts under the rating that’s designed for the led boost circuit?
Reason is I keep blowing led when I replace them, the keep failing even the original ones that’s on the strip. I guess I want to lower the current or the voltage or both.
