I can't imagine any tester that can "reliably" test in-circuit. A simple DVM might test bipolar or FET junctions for obvious shorts/opens, but that possibility is governed by the surrounding circuitry.
Whenever possible, I advocate symptom-driven trouble-shooting with power applied, but that generally means you have schematics in hand. Experience helps but you learn/acquire that.
Good luck!
Good luck!
They have been around for decades and they do work if the associated circuit is no too extreme. I have a B&K 530 http://bee.mif.pg.gda.pl/ciasteczkowypotwor/B&K/B&K 530 Semiconductor Tester.pdf that can test transistors in circuit, identify them etc. Out of circuit it can even check the Ft of the transistors.
I had a VuData that was similar. it was more industrial but also could test transistors for function in circuit. Vu-data 5110 transistor tester, calibrated, warranty
I think the Peak can also work in circuit. Peak Atlas DCA model DCA55 | Peak Electronic Design Limited
....I have a B&K 530 http://bee.mif.pg.gda.pl/ciasteczkowypotwor/B&K/B&K 530 Semiconductor Tester.pdf that can test transistors in circuit, identify them etc. Out of circuit it can even check the Ft of the transistors.....
I used one of those along time ago (in the 1970s) & it worked much better than I expected it to.
B&K Precision 530 Semiconductor / transistor tester | eBay
I still prefer an old Tektronix curve tracer, for testing the devices out of circuit, but since I retired, I no longer have access to one or the space to put one.
Those in circuit testers look expensive. Its possible to test some things in circuit if the power is on and you know how the circuit works. If a BJT is on its Vbe will be around .5-.6v. Vce will not be a short (but it might be as low as .2v). If theres a resistor attached to the emitter or collector you can see if theres a collector current. If theres a base resistor you can check the base current and with these 2 currents get the transistor beta.(unless its saturated (Vce is .2v)). For fets things are different but still doable. More device dependent.
The picture bought back memories a useful tester.I used one of those along time ago (in the 1970s) & it worked much better than I expected it to.
Loved the TEK curve tracer, model 37x series, easy to observe power transistor breaking down by voltage or current. Used to cutoff the TO3 case to see & learn from the damage at the junction.
- Design & Build
- Equipment & Tools
- In circuit transistor tester?
