Hi!
I have a problem with transferning the U bit data from cs8406 to cs8416. I succefully transmitted a modified C data. But I need to transmit data as U bit data. My source is in the U data buffer on CS8406, I use 1 byte long blocks, I disabled the E to F buffer tranfser for the C bit data, and enabled for u bit data. But I read nothing from the other sides CS8416 U-buffer.
Can somebody help me? Pls!
