Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
New Project - Network Streaming Device (Pi4/Hifiberry)
Old 28th June 2020, 07:08 PM   #1
chrisjmartini is offline chrisjmartini  United States
Default New Project - Network Streaming Device (Pi4/Hifiberry)
* Raspberry Pi 4 (2gb)
* Hifiberry DAC+ DSP
* micro SD card for the OS
* Volumio Audiophile Music Player (Debian based Linux distribution customized for the pi and music streaming)
The hardware build only took about 20 mins: Imgur: The magic of the Internet
* Connected to my NAD integrated amp via optical cable.
* Connected to my home network via wifi. I'm going to change this to a hard wired ethernet connection after I free up an additional port.
The software took a bit longer... Days longer. Ran into some issues.
But first, what went right:https://imgur.com/a/usRswBB
  • Installing the OS and getting the basic player and streaming functions was not that difficult. Volumio found all my network shares & Plex server easily. Access to the box via my phone's browser was also pretty simple. Pretty much all functions can be controlled remotely that way, or by using a web browser on a laptop, desktop or tablet (windows & mac).
  • Spotify connect was enabled easily enough through an available plugin for Volumio.
  • Volumio has native tidal and Qobuz support for the paid license.
  • There's always airplay and bluetooth connectivity built in for when you have no other more direct streaming options.
Now, onto what went wrong:
Installing the software to access the 'DSP' part of the Hifiberry board proved to be quite a challenge!
  • The DSP Tools software package that interfaces with the DSP chipset requires a recent version of Python. Volumio is built on an older version which the DSP Tools doesn't support. So a Python 3.x version needed to be compiled and installed.
  • The instructions to do this, while lengthy, did not look too daunting. I'm no stranger to the Linux command line, though not an expert by any stretch of the imagination.
  • This also means getting 2 versions of Python to play nice together on the same machine in such a way that the applications that require the older version can find it, as well as other applications/packages requiring Python 3.x to be able to find it. This is where I ran into trouble, Errors upon errors returned after following instructions to the letter. I ended up reformatting the SD card and starting from scratch 3 times to get this right. In the end, I have not yet been able to get DSPtools installed correctly in order to access the DSP functions.
  • I have had some wonderful help from a user over on the Volumio forums that has a similar hardware setup. I'll post updates.
Last edited by chrisjmartini; 28th June 2020 at 07:27 PM. Reason: Added title image
New Project - Network Streaming Device (Pi4/Hifiberry)Hide this!Advertise here!
hifiberry digi + pro project with separate regulated power ForsbackaKalle Digital Source 10 8th April 2019 08:31 PM
(Project Idea) 4x4 diy usb audio device powered by raspberry pi 3 mry0guy PC Based 1 2nd December 2016 06:12 PM
600W Class D TAS5624A Amp, with USB, HDMI, Bluetooth, and RasPi for Network Streaming brentsinger Class D 17 8th April 2016 02:42 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
