Hi, I have unearthed my old HHB Portadisc and want to record some old cd audio with it. I assume I should use the XLR input and so will need an XLR/jack (that fits into headphone sockets). So, is this right? If so what would I look for when buying? If I should be using some other input (coaxial?) please advise.
cheers
Brendan
cheers
Brendan
Manual:
http://www.hhb.co.uk/hhb/global/brochures/pdiscug.pdf
Looks like the XLRs take balanced line in. Is your CD player balanced out? Probably not..
The cheap and dirty way is to connect the shield to XLR pins 1&3 (G & Return), signal core to pin 2 (line). Hopefully you'll have enough gain, otherwise switch from line to mic.
