Amanero firmware or design issue or something else
Thread Tools
Old 20th April 2021, 11:40 PM   #1
nemantree is offline nemantree
Default Amanero firmware or design issue or something else
I'm experiencing the issue with cracked sound in one channel of my DAC (thru Windows Direct Sound only / ASIO is OK).
Left channel sounds distorted at the Windows Default Format Test tone when I select greater than 16-bit/44.1Khz sample rate. Right channel is OK.
I've localized the root cause is Amanero USB input +- Direct Sound.
(1 it is not the Windows driver - the same thing happens on diff PC/Windows7/10;
2 not the AK4137->D/A->Analog path - because it sounds good when S/PDIF input AK4118 gets used)
I've already tried to flush bunch of different Amanero firmwares
Amanero Technologies
The results are all basically the same: either there is no sound at all or there is same issue.
The Amanero USB receiver is 100% original - got it from from their .com.
I have the AK4137 (and whole DAC) clocked asynchronously from its own master clock.
Well ... via ASIO/WASAPI everything sounds and measures OK. Just the Direct Sound via USB and one channel.
Stepped on the rakes Gentlemen, need some advise/clue/hint from you.
Thanks in advance!
Old 21st April 2021, 11:41 AM   #2
Markw4 is offline Markw4  United States
If you turn down the volume in Windows does that have any effect on the distortion?
Is the AK4137 configured to expect other than I2S PCM format (maybe LJ)?
Why use direct sound at all given that sound quality suffers compared to properly configued ASIO?
Also, not about Direct Sound-related distortion, but there should be no reason to use ASRC with asynchronous USB. Amanero can be configured to use an external clock source, which ideally should be derived from the dac clock. Then ASRC would only be needed for SPDIF.
  Reply to this post
Amanero firmware or design issue or something elseHide this!Advertise here!
Thread Tools
Grounding Issue or Something Else? msft Headphone Systems 8 8th April 2021 01:33 AM
Denon DVD-3910 Firmware and Issue gcalvas Digital Source 0 20th February 2020 04:18 PM
Amanero firmware upgrade on chinese clone boards? Kovax Digital Source 0 19th August 2018 06:38 PM
Something else about me Sch3mat1c Everything Else 2 3rd February 2003 08:58 PM
Borealis or something else ? Jean Multi-Way 7 11th September 2002 04:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
